Nissan Frontier 2004-6 cylinder
brianl
Member - Posts: 6
Posted: February 19, 2004 at 9:07 PM / IP Logged
I am looking for alarm/remote starter wirining info.
draasch
Gold - Posts: 2,172
Posted: February 20, 2004 at 7:49 AM / IP Logged
all i have is the 2003. you can double check the wires:
Make:   Nissan
Model: Frontier
Year:    2003
This Database Was Last Updated On:    6/9/2003
Index #: 351
Alarm
Constant 12 volts GREEN IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light GRAY/BLACK (-) DRIVERS KICK PANEL
Trunk Pin Switch
Parking Lamp BLUE/RED (+) AT HEADLIGHT SWITCH
Power Lock GREEN/ RED DRIVERS KICK #201
Power Unlock BROWN PANEL
#201 See Negative Pulse Door Lock Diagram
Remote Start
Tach Signal PINK/BLUE AT IGNITION COIL #239
Ignition #2 RED / YELLOW IGNITION SWITCH HARNESS
Ignition #3
Accessory WHITE/ BLUE IGNITION SWITCH HARNESS
Neutral Safety YELLOW (-) AT RELAY CENTER UNDER HOOD
Brake Light BROWN / RED (+) AT SWITCH ABOVE PEDAL
Reverse Light YELLOW/RED (+) DRIVERS KICK PANEL
Rear Window Defrost
#239 See Immobilizer Bypass Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
