2000 Malibu, Autopage rf-1055ke
sgray
Posted: February 19, 2004 at 3:59 PM / IP Logged
I got a question about installing a autopage keyless entry system (RF-1055KE)  in a 2000 cheverolet malibu,  on the main wiring harness of the keyless unit the wiring harness has 9 wires  im going to make a list of how it goes
Green-Parking light output(10A)
Red(+)- 12V Main Power (15A)
Blue-Horn Output (-)
Black - Main Ground
BLACK/ White- Starter interrupt (500 mA Gound Output)
Yellow- 2nd Channel (200 mA Gound OUtput
Blue/White- 2 Step Unlock (-) output
Orange - Domelight Output
White- Switched Ignition Input
I know were the other ones goes but the Yellow 2nd Channel i do not know what is it for and also the Blue/White wire what is it for  are what should it hook to could someone post me some info trying to install this weekend.
kgerry
Platinum - Posts: 3,455
Posted: February 19, 2004 at 4:08 PM / IP Logged
yellow would only be hooked up if you were using this Aux output, like to a relay to pop the trunk, etc.
Blue/white is only hooked up if the vehicle has priority door locks and you want to incorporate this feature
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sgray
Posted: February 22, 2004 at 3:25 PM / IP Logged
Im instlaling Autopage rf-1055ke and i got power and my parking lights are working but nothing else i installing in a 2000 chev malibu and when i connect the wires up i get nothing from the locks i think i go a 3 wire positive trigger door lock system the wires do not go to any relay and it has a 12V source running to the switch he is how the wiring harness goes on my system
Light Blue-Door Unlock(-) Door Lock+
Red -12 Volt Output + Supplied By alarm
Light Green- Door Lock(-) Door Unlock(+)
I need to know what is the Red 12 volt output for supplied by alarm what does it hook to because im getting nothing from my door locks
prdjr165
Copper - Posts: 293
Posted: February 22, 2004 at 3:37 PM / IP Logged
you don't need the red wire,just hook up the lt/blue wire to the lock(lt/blue)wire and the lt/grn to the unlock (white)wire.That red wire is for the coil side of relays.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
