95 Inegra Remote Entry
FiremanDan
Posted: February 23, 2004 at 1:11 PM / IP Logged
Im am thinking about removing the external door handles of my Integra and using the factory alarm/keyless entry to unlatch the doors, and have several questions:
I assume the factory "unlock" solenoids are not powerfull enough to unlatch the doors, but can I just use the existing wiring to drive larger solenoids?
Are there any space issues with mounting larger solenoids(I haven't looked inside the doors yet)?
Can anyone suggest the required solenoid pull for an application like this?
Will I need "poppers" or do these latches have enough kick by themselves.
(My biggest problem is I don't currently have access to the car, it is in a shop about 100 miles away.)
I would appreciate any input from someone who has tried this sort of thing.
     Thanks in advance,
     Dan
defective
Silver - Posts: 642
Posted: February 23, 2004 at 4:25 PM / IP Logged
well.... just normal trunk release solenoids should work fine, it's a honda.     as for the doors, you will need poppers, just test pulling the door handle fron the outside once, then try to pull the door open, you'l notice they will open a crack but will not move any further (you know when you close it sloppy and gotta give er the old hip check).
FiremanDan
Posted: March 01, 2004 at 11:42 AM / IP Logged
Thanks for the advice!
Anyone else have any experiance with electric door releases on an Integra? Any trouble finding space/mounting the solenoids?
Thnx,
Dan
draasch
Gold - Posts: 2,172
Posted: March 01, 2004 at 1:33 PM / IP Logged
hey dan,
they make door popper kits for shaved handle cars.....i will send you some info wheni find it. it wont be until later tomorrow night. im on duty today.....
later,
david
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jgold47
Copper - Posts: 69
Posted: March 01, 2004 at 3:26 PM / IP Logged
www.team-integra.net
chances are you will find it there....
