alarm chirping?
BangBang
Silver - Posts: 287
Posted: February 24, 2004 at 2:52 PM / IP Logged
my alarm use to chirp twice wen i un lock, and chirp once wen i lock.
now when i lock it chirps, once, then 2 seconds later chirp once.
same with unlocking, it'll chirp twice, then 2 seconds later chirp one last time... wtf is up?
help me plz?
also my neon lights. does the fuse have to be close to the battery as possible? cuz i have my neon light fuse in my car lolz..
draasch
Gold - Posts: 2,172
Posted: February 24, 2004 at 3:08 PM / IP Logged
what brand of alarm is it???
and yes you what the fuse to be as close as possible to the power source..........
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
JMaxx93
Copper - Posts: 73
Posted: February 24, 2004 at 4:44 PM / IP Logged
it sound like you have a zone that is open.  or in other words if you have a hood pin or some other alarm trigger it may not be recognizing it as closed. another  posibility is the ignition wire has work loose depending on how it was connected.  if not that then i would also make sure it has a solid ground.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
