toyota corolla 2004
Power
Member - Posts: 16
Posted: February 25, 2004 at 12:54 PM / IP Logged
i want to know if you got any information of wire diagram for the toyota TOYOTA COROLLA 2004
mass
draasch
Gold - Posts: 2,172
Posted: February 25, 2004 at 2:58 PM / IP Logged
here is the 03 info.....double check with a meter!
Make:   Toyota
Model: Corolla
Year:    2002-03
This Database Was Last Updated On:    6/9/2003
Index #: 592
Alarm
Constant 12 volts WHITE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter RED IGNITION SWITCH HARNESS *
Dome Light RED / WHITE (-) IGNITION SWITCH HARNESS **
Trunk Pin Switch RED / WHITE (-) AT LIGHT IN TRUNK
Parking Lamp GREEN (+) CONNECTOR ON BACK OF FUSE BLOCK ***
Power Lock BLUE/WHITE 10 PIN CONNECTOR ****
Power Unlock BLUE / YELLOW IN DRIVER KICK PANEL #209
* Remove Positive Battery Terminal If Cutting To Prevent Check Engine Light. ** RED / WHITE (-) Key cylinder switch light. If This Only Gets Dr. Door Alt Location Is At The Back Side Of Drivers Side Fuse Junction Block. ***12 Pin Connector **** Child Safety Lock - WHITE (-) In 10 Pin In Driver Kick Panel. #209 - See Child Safety Door Lock Diagram.
Remote Start
Tach Signal BLACK AT ENGINE CONTROL MODULE *
Ignition #2 BLACK / YELLOW IGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3 N/A
Accessory BLUE/RED IGNITION SWITCH HARNESS
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light RED / BLACK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost BLACK/ BLUE (-) AT SWITCH
* Engine Control Module Is Located Behind The Center Console In Pin 27 Of The 28 Pin Connector.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Xmc Sam
Member - Posts: 19
Posted: February 26, 2004 at 1:16 AM / IP Logged
The door lock wires are different on a 04, i just dont remember the colors, sorry!! Same plug though... drivers kick
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
