2003 Dodge Caravan Alarm
domiyork
Member - Posts: 38
Posted: February 25, 2004 at 7:26 PM / IP Logged
 Hi,
 Installing an alarm tomorrow on this van, any hints, ideas. Also how to wire the powerlocks. Please send wiring diagram.
 cheers.
mo12v
Posted: February 25, 2004 at 7:49 PM / IP Logged
Constant 12 volts L BLUE IGNITION SWITCH HARNESS *
Ignition 12 volts PINK/WHITE IGNITION SWITCH HARNESS **
Starter YELLOW (+) IGNITION SWITCH HARNESS
Dome Light YELLOW/WHT (+) PIN 33 OF 34 PIN CONN. AT B.C.M.
Trunk Pin Switch VIOLET/ORANGE (-) PIN 29 OF 34 PIN CONN.AT THE B.C.M.
Parking Lamp WHT/BRN(RESISTOR SYS.) AT HEADLIGHT SWITCH (SEE TECH NOTES)
Power Lock /UNlock
SINGLE WIRE SYSTEM ***
VIOLET/D GREEN AT B.C.M.LOWER LEFT OF STEERING COLUMN IN PIN 21 WHT 34 PIN CONN.#217
* All Wires Are 20 Gage.L BLUE Fused At 10 Amps. For main Power Connection Connect To BROWN / RED Or WHITE/ RED Fused At 20 Amps At 6Pin Conn. At B.C.M. ** Ignition Wire Controls All Accessories. *** Chassis Ground Thru A 5.3k To Lock And Chassis Ground Thru A 2k Ohm Resistor To Unlock. ( Connector Is Third Up From Bottom Of BCM)  Single Wire Resistor Door Lock/Unlock
Accessories
Window Up D\ORG/LT GRN P\ORG/TN D\ORG/D BLU P\ORG/GY @ MAIN
Window Down F/ORG/WHT F/ORG/D GRN R/ORG/L BLU R/ORG/D GRN SWITCH
Ign Key Warn VIOLET/BROWN (-) IGNITION SWITCH HARNESS
Trunk Release HATCH RELEASE:VIOLET/ TAN (-) THRU 1.69k RESISTER @ BCM
OEM Horn D GREEN/ VIOLET (-) STEERING COLUMN
Headlights WHT/YEL WHT/BR AT HEADLAMP SWITCH RESISTANCE VALUE *
OEM Alarm Arm VIOLET/LT BLUE (-) PIN 14 AT 34 PIN CONNECTOR,RESISTERS
OEM Alarm Disarm VIOLET/LT BLUE ARE THE SAME AS LOCK & UNLOCK BUT **
* 788-809 Ohms ** Apply In The Opposite Direction. Reversal Rest At Ground Power Window Circuit Diagram. : Right Slider Open/Close Chassy Ground Thru 3900 Ohm Resistor On Glossy VIOLET / YELLOW at B.C.M Right Of Steering Column. Hood Ajar Switch - VIOLET/LIGHT BLUE (-) Pin 30 White 34 pin Conn. At B.C.M.
Remote Start
Tach Signal D BLUE/D GREEN PIN 11 GRAY/BLACK 40 WAY CONN.P.C.M.*
Ignition #2  See Note Below **
Ignition #3
Accessory
Neutral Safety WHITE/ LT GREEN PIN 9 OF 34 PIN CONNECTOR AT BCM
Brake Light WHITE/ TAN (+) AT SWITCH
Reverse Light WHITE/ LT GREEN (+) PIN 9 OF 34 PIN CONNECTOR AT BCM
Rear Window Defrost
* Power Control Module Located Left Front Corner Of Engine Compartment. Ignition Input To Keyless:PINK/WHITE ** VIOLET/BROWN and VIOLET/ORANGE Must See 180 OHM Resistor Between Them During Start Due To Multiplexing.  Immobilizer Bypass Diagram.
TECH NOTES:
This Vehicle Has A Resistored Park Light System.The WHITE/ BROWN Wire Must Be Cut And A relay And Resister Must Be Used. Pin 85 To Ground Pin 86 To The WHITE Wire Of The Alarm.Pin 87A Switch Side Of WHITE/ BROWN Wire,Pin 30 BCM Side Of WHITE/ BROWN Wire. Pin 87 To One Side Of A 5.8k Ohm Resistor,The Other Side Of The Resistor To Ground. There Is A WHT/DK.BRN In The Rear Harness (Driver Kick) That Is A Pos 12v To The Tag Lights.: Door Lock/Unlock Wire Located On The Third Connector Up From The Bottom.
MO
domiyork
Member - Posts: 38
Posted: February 25, 2004 at 7:59 PM / IP Logged
 Thanks for all the great info. Will try tomorrow.
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
