wiring diagram for 04' maz 6?
Welcome Guest :)
proinstall
Copper -
Posted: February 28, 2004 at 12:08 PM / IP Logged
rem start/alarm wiring.. anyone do one of these yet?
JMaxx93
Copper -
Posted: February 28, 2004 at 12:16 PM / IP Logged
| 12volts | black and BLACK / YELLOW | + | ignition harness | | Starter | BLACK/ blue | + | ignition harness | | Second Starter | N/A | | | | Ignition | blue | + | ignition harness | | Second Ignition | N/A | | | | Third Ignition | N/A | | | | Accessory | BLACK/ red | + | ignition harness | | Second Accessory | BLACK/ white | + | ignition harness | | Keysense | WHITE/ blue | + | ignition harness | | Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors. | | Power Lock | lt. green | - | DKP or door lock module | | Notes: Lock is negative trigger thru a 1.4K ohm resistor. Unlock is a straight negative trigger. MUST use relays.The door lock control module is located above the passenger kick panel. | | Power Unlock | same wire as power lock | | | | Lock Motor | RED / blue | 5wi | DKP or door lock module | | Notes: The door lock control module is located above the passenger kick panel. | | Unlock Motor | RED / green | 5wi | DKP or door lock module | | Notes: The door lock control module is located above the passenger kick panel. | | Parking Lights+ | lt. GREEN/ black | + | driver kick, 14 pin plug | | Parking Lights- | RED / white | - | headlight switch | | Hazards | blue/orange | - | switch or door lock module | | Notes: The door lock control module is located above the passenger kick panel. | | Turn Signal(L) | WHITE/ black | + | steering column | | Turn Signal(R) | WHITE/ red | + | steering column | | Reverse Light | RED / yellow | + | driver kick, 14 pin plug | | Door Trigger | GREEN/ orange | - | DKP or door lock module | | Notes: The door lock control module is located above the passenger kick panel. | | Dome Supervision | yellow/black | - | DKP or door lock module | | Notes: The door lock control module is located above the passenger kick panel. | | Trunk/Hatch Pin | brown | - | DKP or door lock module | | Notes: The door lock control module is located above the passenger kick panel. | | Hood Pin | gray/red | - | pin switch or theft module | | Notes: The theft-deterrent control module is located in the center console. | | Trunk/Hatch Release | yellow | - | switch or door lock module | | Notes: The door lock control module is located above the passenger kick panel. | | Power Sliding Door | N/A | | | | Factory Alarm Arm | blue | - | DKP or door lock module | | Notes: Arm is negative trigger thru a 1.4K ohm resistor. Disarm is a straight negative trigger. MUST use relays.The door lock control module is located above the passenger kick panel. | | Factory Alarm Disarm | same wire as alarm arm | | | | Disarm No Unlock | use key sense wire | | | | Tachometer | NOT blk/wht or grn/stripe | ac | ignition coil or coil pack | | Notes: On the 4 cyl models use the wire that is NOT BLACK/ white. On the 6 cyl models use the wire that is NOT GREEN/ stripe. | | Wait to start | N/A | | | | Brake Wire | green | + | brake pedal switch | | Parking Brake | brown | - | parking brake switch | | Horn Trigger | PURPLE / white | - | column or door lock module | | Notes: The door lock control module is located above the passenger kick panel. | | Memory Seat 1 | N/A | | | | Memory Seat 2 | N/A | | | | Memory Seat 3 | N/A | | |
| Immobilizer Bypass Module: | Required: Yes | Type: Transponder | Part #: 555U | | Notes: N/A |
proinstall
Copper -
Posted: February 28, 2004 at 2:29 PM / IP Logged
thanks man.. I have a password for that site somewhere around here.. I gotta find it..
Friday, February 13, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
