97 f150 pwr door locks
Amangill
Member - Posts: 13
Posted: February 29, 2004 at 9:44 PM / IP Logged
hi iam installing an alarm in my truck and i cant find the door lock,unlock wires in the wiring diagram it says that it is pink/yello and pink/lt green but i cant find the wires and this truck does not have an keyless entry and if it is where would the module would be? and are the door locks neg trigger or possitive? thanks
if anyone
aman
draasch
Gold - Posts: 2,172
Posted: February 29, 2004 at 9:59 PM / IP Logged
that is the correct colors.....
Make:   Ford
Model: Pickup - Fullsize
Year:    1997
This Database Was Last Updated On:    6/9/2003
Index #: 9045
Alarm
Constant 12 volts YELLOW (2), ORG/YEL & L GREEN/ PURPLE (2) IGN. SW. HARNESS
Ignition 12 volts D BLUE/GREEN IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ L BLUE (+) PASSENGER KICK PANEL
Trunk Pin Switch N/A
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH
Power Lock PINK / YELLOW DRIVER KICK * #203
Power Unlock PINK/L GREEN PANEL #201
* Without OEM Keyless Entry See Note #203, With OEM Keyless Entry See Note #201. #203- See Reversal Rest At Ground Door Lock Diagram. #201- See Negative Pulse Door Lock Diagram
you should be able to find them in the drivers kick
http://wiringinstructions.com/203.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
