Alarm sensor
benokolo
Posted: April 08, 2002 at 12:16 AM / IP Logged
I have a 1996 Mazda 626 with an after mareket (BICRON) alarm systems, The Remote control is not able to activate or deactivate the alarm. When the botton on the remote control is pressed, the light on it flashes but no action is executed. the flashing red light on the dashboard is flashing randomly and there is a single tone that sounds constantly even when the car is running. The sound is like the one you hear when the key is left in the ignition or the light is left on. What seems to be the problem.Alarm sensor -- posted image. Could you help me?
benokolo@usa.net
90303
Thinkster
Copper - Posts: 94
Posted: April 08, 2002 at 1:51 AM / IP Logged
First, what does this have to do with "Alarm Sensor" ??
As far as the alarm goes,  can you put the alarm into Valet mode?  If so, does the LED stay solid lit?  Regarding the tone,  can you Disconnect the alarm and see if the tone goes away?
As far as the remote is concerned, it is possible for the LED to flash when pressing the button, but for the transmit to be not there or to be off Frequency.  I've repaired hundreds of remotes and have commonly had to replace the tuning cap in them among other things.
Elizstoy
Member - Posts: 38
Posted: October 19, 2002 at 6:11 AM / IP Logged
Would you happen to have the wiring diagram for your BICRON alarm? Thanks
