98 ford windstar door locks
beav
Member - Posts: 14
Posted: March 04, 2004 at 7:09 PM / IP Logged
I recently installed a remote starter with keyless entry into a 98 ford windstar and whenever i press the lock/unlock button on the remote the locks click 3 times in the same direction.  I tried changing the setting so it had only one pulse and a .75 second pulse and it still doesn't help. I also tried to put the settings back to default and it still clicked 3 times instead of the normal once. So i tried to change those settings again and it didn't help any. Does anybody have any ideas on why it clicks 3 times instead of just the normal one.
bmf1000d
Silver - Posts: 345
Posted: March 04, 2004 at 11:42 PM / IP Logged
What RS alarm are you installing?
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
beav
Member - Posts: 14
Posted: March 05, 2004 at 1:34 AM / IP Logged
beav
Member - Posts: 14
Posted: March 05, 2004 at 1:43 AM / IP Logged
The Galaxy 5000 RS 2W
Dbfordtech
Member - Posts: 28
Posted: March 05, 2004 at 6:21 AM / IP Logged
Hey Beav,
I assume your Windstar has factory keyless entry.
If so, you should be sending a NEGATIVE pulse to a pink / YELLOW wire in the drivers kick panel to lock and
a NEGATIVE pulse to  the pink/light green to unlock in the drivers kick panel.
If your remote starter has only a positive lock/unlock pulse, or reverses polarity, you will need to install relay(s)
to keep the signals negative.
Also, test these wires carefully, there are often more than one of each colour.
beav
Member - Posts: 14
Posted: March 05, 2004 at 2:19 PM / IP Logged
I hooked it up to those wires and the starter uses a negative pulse to unlock the doors. The windstar does not have factory keyless entry but does have automatic door locks. It still does the same thing. Is there any other ideas that you think could fix this because i am stumped.
Dbfordtech
Member - Posts: 28
Posted: March 05, 2004 at 9:32 PM / IP Logged
No factory keyless entry? Thats rare!!! No problem though. Give me an E-mail address and I will send you a schematic for reverse polarity 5 wire door locks.
Moderator - Posts: 12,488
Posted: March 05, 2004 at 9:56 PM / IP Logged
All my information says that it's a(-) trigger system as well. Make sure that the ground that you used for the system is sufficient. Paint free and dirt free as well straight onto metal. If the ground is bad or not good enough, this will give the system poor performance or irratic behaviors.
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
