remote start with out hand brake up
silver hatch
Member - Posts: 9
Posted: March 08, 2004 at 12:18 AM / IP Logged
ok i have a 96 civic and ive installed a crimestoppers CS-2015FM alarm. i installed the remote start on my car even though it a manual transmission, what i want to do is, i dont want my remote start to work unless my hand brake is up what do i need to do, i know i need a relay  but im not sure on how to connect it. i know my remote start wont work if my trunk or hood is open, i also dont want it to start if my hand brake isnt up.
draasch
Gold - Posts: 2,172
Posted: March 08, 2004 at 12:23 AM / IP Logged
if you have a switch on the brake to show when its up or on, you should be able to use that switch...if not you may be able to use a pin switch so that it will ground out like your hood pin switch so that it wont start...
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
JakeJ
Member - Posts: 38
Posted: March 08, 2004 at 12:52 AM / IP Logged
   You might run into a problem with your alarm thinking your "hood" is open. It might false or not arm properly. Try using the relay to cut the start wire output of the CS-2015FM if the brake is not up. That way if the relay isn't activated by the brake being up the power to the start wire will never get there.
Wyoming 12volt Enthusiast
Mattthew278
Copper - Posts: 52
Posted: March 08, 2004 at 5:02 AM / IP Logged
Hey, if you haven't figured it out yet, email me at mattthew278@aol.com, put alarm or something in the subject so I won't delete it.  I also installed a crimestopper into a manual transmission, using the Hood pin wire.  I can tell you exactly what I did.
monzie32
Member - Posts: 6
Posted: March 13, 2004 at 5:46 PM / IP Logged
take neg shutdown wire to starter and in console of car where the e brake is under the plastics you will see the manual switch there tie it in and diode isolate it to stop feedback--
soultinter
Copper - Posts: 170
Posted: March 14, 2004 at 3:23 PM / IP Logged
BAD BAD BAD    why not buy a unit made for manual trans????  much safer!!!!!
sroth140
Silver - Posts: 513
Posted: March 15, 2004 at 12:24 AM / IP Logged
most remote start units have a negative shut down wire that you run to a toggle switch then ground it.  then, most of the time the e-brake has a wire that gets a ground signal when the lever is pulled to turn on the dash warning light... find if thats + or - (might need a relays) but just run that toggle switch wire through it in series, then to ground.
MECP certified installer
Ger45
Member - Posts: 12
Posted: March 21, 2004 at 8:02 PM / IP Logged
I WOULD JUST USE THE NEGATIVE OUT ON THE E BRAKE TO TRIP A RELAY AND BRAKE CONNECTION ON THE STARTER WIRE IF IT IS NOT SEEING THE GROUND
goose!
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
