SRX, not easy-good luck ?
radiostation
Member - Posts: 15
Posted: March 08, 2004 at 7:15 PM / IP Logged
has anyone actually done remote start on this beast? OK- besides the fact that the styling is <questionable> how is this thing wired? Do we use Passlock or Transponder? any other Caddies similar? Please be specific if you have done this vehicle, I've got one on 3/10/04 and want to get it right the first time (if possible) What the heck is this thing? Thanks for ANY info, Steve
The Radio Station, inc. Now in Pawling New York
auex
Platinum - Posts: 5,041
Posted: March 08, 2004 at 7:21 PM / IP Logged
I show transponder, so a defeat like 555U. Haven't done one though.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
diabloed
Copper - Posts: 133
Posted: March 08, 2004 at 9:07 PM / IP Logged
WIRING INFORMATION - CADILLAC / SRX / 2004 / Remote Start
12volts RED / white x2 (10A each)   +   ignition harness
Starter yellow   +   ignition harness
Ignition pink   +   ignition harness
Accessory orange   +   ignition harness
Second Accessory brown   +   ignition harness
Keysense lt. green   -   pin B10, brown plug at DIM
Notes: The DIM (Dash Integration Module) is under the glove box.
Power Lock ORANGE / black   -   driver door lock sw. in door
Power Unlock ORANGE / black   -   driver door lock sw. in door
Parking Lights+ DO NOT USE
Parking Lights- BROWN / white   -   pin B3, brown plug at DIM
Door Trigger gray   -   underdash light
Notes: Individual door triggers are in each door at their respective door modules. The driver door trigger is tan, the RF door is lt. green, the LR door is dk. blue/white, and the RR door is yellow/black. Use all four wires and diode isolate each.
Dome Supervision comes on with disarm
Trunk/Hatch Pin ORANGE / black   -   pin B3, red plug at RIM
Notes: The RIM (Rear Integration Module) is in the right rear quarter panel.
Hood Pin pnk/blk (export model only)   -   pin B1, brown plug at DIM
Factory Alarm Arm yellow (export model only)   -   driver door module in door
Factory Alarm Disarm lt. green   -   driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white   ac   ECM
Notes: The ECM (Engine Control Module) is on the passenger side of the motor under the cover on the 3.6L, and it is on the left frame rail below the driver side headlight on the 4.6L.
On the 3.6L, tach is in pin 5, connector 2. On the 4.6L, tach is in pin 26, blue plug.
Brake Wire white   +   driver kick, harness to rear
Parking Brake lt. blue   -   parking brake switch
Horn Trigger tan   -   pin A6, gray plug at DIM
Memory Seat 1 white   -   memory seat switch in door
Memory Seat 2 purple   -   memory seat switch in door
Immobilizer Bypass Module: Required: Yes Type: Passkey 3 Plus Part #: 555U
Notes: N/A
Platinum - Posts: 12,488
Posted: March 09, 2004 at 12:10 AM / IP Logged
Use the GMDL2 for the OEM alarm as well as the door lock wires. This way you don't have to go into the doors and run 4 new wires for the locl/unlock and arm/disarm. Knowing those Caddy's, the door boot will be a pain to get into. The module uses the databus wire instead and also can auto roll up the windows upon locking the car with the remote FOB
radiostation
Member - Posts: 15
Posted: March 12, 2004 at 6:21 AM / IP Logged
Jeff- didn't try the module, just went into door which was not too bad. Do you know that the GMDL2 will work that vehicle ? Otherwise not too bad as far as newer cars go. Thanks, Steve
The Radio Station, now in Pawling NY
DanDan
Copper - Posts: 125
Posted: March 12, 2004 at 7:17 AM / IP Logged
Easy car to do. The vehicle uses the Passkey 3+ transponder. I use the bypass from Omega which is the Trilogix piece and works great and easy to program. The info above is incorrect for the brake wire. That is located under the rear seat by the fuse panel on the drivers side. It is a white wire but there is no brake switch up front. It uses a totally different system that tells the computer where the brake pedal is. The tach wire is behind the instrument cluster. It is a white wire but there are two. I would have to look up my notes. The cluster is much easier to get to than running a wire to the engine compartment. Getting wires into the doors are easy. Boots are no problem. Besides that the only problem I had is the wires going to the ignition are extremely thin and I had to downsize the remote start wires to smaller ones so they did not break the factory wires. I solder all connections and had reservations about tapping those wires with such big wires from the remote start. Use a bypass module and if your not using the factory remotes get the databus module.
DanDan
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
