need wire diagram for 93 chevy lumina
bigal3du
Member - Posts: 8
Posted: August 17, 2002 at 3:09 PM / IP Logged
Hey,
I'm doing an install of a CS2011RS car alarm on my 1993 Chevy Lumina Euro 4D Sedan and I need a wiring diagram, can anyone help me with that?
Thanks!
Platinum - Posts: 12,488
Posted: August 17, 2002 at 3:25 PM / IP Logged
|              12V|red                 |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|pink                |+  |ignition harness            |
|  SECOND IGNITION|dark blue/white     |+  |ignition harness            |
|        ACCESSORY|orange              |+  |ignition harness            |
| SECOND ACCESSORY|PURPLE / white        |+  |ignition harness            |
|       POWER LOCK|lt. blue            |+  |either kick                 |
|     POWER UNLOCK|black               |+  |either kick                 |
| PARKING LIGHTS +|brown               |   |headlight switch *1         |
|       HEADLIGHTS|yellow              |+  |headlight switch            |
|     DOOR TRIGGER|white               |-  |headlight switch *1         |
| DOME SUPERVISION|use door trigger    |   |                            |
|TRNK/HTCH RELEASE|black               |+  |release switch              |
|       TACHOMETER|pur/wht or white    |   |igniton coil *2             |
|      SPEED SENSE|green               |4  |PCM *3                      |
|       BRAKE WIRE|white or lt. blue   |+  |brake switch                |
|     HORN TRIGGER|black               |-  |steering column             |
|           WIPERS|purple              |+  |wiper switch                |
|  LF WINDOW UP/DN|dk. blu - brown     |A  |drivers door motor          |
|  RF WINDOW UP/DN|dk. blu/wht - tan   |A  |in drivers door or dkp      |
|  LR WINDOW UP/DN|dk. grn - purple    |A  |in drivers door or dkp      |
|  RR WINDOW UP/DN|lt. grn - pur/wht   |A  |in drivers door or dkp      |
Notes:
*1 Also found low in the drivers kick panel.  *2 Also found at the instrument cluster as white.  *3 The PCM is located in the passenger kick panel.  The VSS wire is also found at the instrument cluster.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
