98 dodge caravan alarm/start
danida
Posted: March 19, 2004 at 2:17 PM / IP Logged
Hi,
I noticed that my alarm has 7 wires for the ignition and my car (dodge caravan 98) has 5 wires: 12v+,starter,ignition1,2,3......looking at the alarm diag. looks that I have to install 4 wires (3 relays) when the ignition is on OFF position (STR,ON,ACC) and then, 3 more from the control module (alarm) witch one of them is connected to the starter (bridge), ON and ACC. What I don't understand is why on position OFF, my alarm has 2 wires going to "ON" of the ignition. Is one negative and the other positive.
Thanks,
David
draasch
Gold - Posts: 2,172
Posted: March 19, 2004 at 2:24 PM / IP Logged
Make:   Dodge
Model: Caravan
Year:    1998
Alarm
Constant 12 volts PINK/BLACK, RED & PINK IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light BROWN / L GREEN (-) GRAY 36 PIN CONNECTOR AT FUSE BLOCK *
Trunk Pin Switch TAN/BLACK 40 PIN NATURAL CONN. AT FUSE BLOCK
Parking Lamp BLACK / YELLOW (+) GRAY 36 PIN CONN. AT FUSE BLOCK **
Power Lock WHITE/ D GREEN BLACK 14 PIN CONNECTOR #217
Power Unlock SINGLE WIRE SYSTEM IN DRIVER KICK PANEL ***
* BROWN / L GREEN (-) Wire Can Also Be Found At Headlight Switch. ** Also Found As BROWN / YELLOW (+) In GRAY 36 Pin Conn. Above Fuse Block. *** See Tech Notes For More Information. #217- See Single Wire Resistor Door Lock Diagram.
View Diagrams
Accessories
Window Up D\ L GREEN P\ BRN/WHT D\ D BLUE P\ GRAY @ MAIN #211
Window Down F/ WHITE F/ VIO/WHT R/ RED / WHT R/ D GREEN SWITCH
Ign Key Warn L BLUE (-) IGNITION SWITCH HARNESS
Trunk Release N/A
OEM Horn BLACK/ RED (-) STEERING COLUMN HARNESS
Headlights L GREEN/ ORANGE (-) AT HEALDIGHT SWITCH
OEM Alarm Arm WHITE/ D GREEN (-) BLACK 14 PIN CONNECTOR
OEM Alarm Disarm WHITE/ D GREEN (-) IN DRIVER KICK PANEL *
#211- See Reversal Rest At Ground Power Window Circuit Diagram. * OEM Arm & Disarm Is The Same As Door Lock Wire. Schematics Do Not Specify Resistor Values, Believed To Be The Same As 1996 Caravan Which Requires Chassis Ground Thru A 4020 Ohm Resistor To Arm And Chassis Ground Thru A 665 Ohm Resistor To Disarm OEM Alarm.
View Diagrams
Remote Start
Tach Signal GRAY & D BLUE/TAN AT POWERTRAIN CONTROL MODULE (2.4L) *
Ignition #2 BLACK/ ORANGE IGNITION SW. HARN. (HEAT/AC) #235
Ignition #3 D GREEN/ RED IGNITION SW.HARN.(TRANS CONTROL MOD.)
Accessory BLACK/ WHITE IGNITION SWITCH HARNESS
Neutral Safety BLACK/ WHITE (-) AT POWERTRAIN CONTROL MODULE
Brake Light WHITE/ TAN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light VIOLET/BLACK (+) BLK 10 PIN CONN. ON DR. FRONT OF ENG.
Rear Window Defrost N/A TIMER BUILT INTO SWITCH
* Each Wire Listed Above Is A 2 Cylinder Signal. 3.0L Tach Wire Is GRAY/RED At Powertrain Control Module (PCM). 3.3L & 3.8L Tach Wire Is GRAY/RED, D BLUE/TAN And RED / YELLOW At PCM (Each Wire Is A 2 Cylinder Signal). PCM On All Models Located On Driver Fenderwell. #235- See Powering Additional Ignitions Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
