96 fleetwood
amador
Copper - Posts: 108
Posted: August 17, 2002 at 11:59 PM / IP Logged
  I'm about to install a car alarm ina 96 cadilac fleetwood with auto start i know that thier is a modual that you can use to bypass the eletronic key.  i also know that thier is a way to do this with a relay i was wondering if anyone knew how to do this and if they could help with sharing the diagram with me thanks everyone
sonic boom
Platinum - Posts: 12,488
Posted: August 18, 2002 at 9:34 AM / IP Logged
Cadillac
Fleetwood
1996
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS**
Ignition  #1:
PINK
Ignition #2:
ORANGE
Ignition  #3:
N/A
Accessory:
BROWN
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
PURPLE (+)
AT CONVENIENCE CENTER MODULE ***
Headlights:
YELLOW (+)
AT CONVENIENCE CENTER MODULE***
OEM Alarm  Disarm:
L GREEN (-)
DRIVER KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Powertrain Control Module (PCM) Located On Driver Front Of Engine Under Air Filter. WHITE Wire Located At Pin #13 In 32 Pin Connector At PCM. ** This Vehicle Is Equipped With GM's VATS Anti-Theft System ;
Cadillac
Fleetwood
1996
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2)
Starter  Kill:
YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
PURPLE (-)
10 PIN CONNECTOR IN DR. KICK PANEL
OEM Horn:
Power  Lock:
L BLUE
DRIVER'S KICK PANEL****
Power  Unlock:
WHITE
Trunk  Release:
BLACK/ WHITE (+)
AT TRUNK RELEASE SWITCH
Alarm  Input Wire:
PURPLE (-)
Notes:
*** Convenience Center Module Located Behind Driver Dash To Left Of Steering Column.BROWN / BLACK (-) At Headlight Switch Can Also Be Used For Park Lights. **** Positive Pulse Door Lock
496 fleetwood -- posted image.  GM Vats Pass Key Bypass (uploaded by the12volt on 5/7/2002)10 KB
 List of resistor values and diagram to bypass GM Vats PASS Key. ...( GMVatsPassKey.gif)
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
