2000 LHS Remote Start
Memphisman
Copper - Posts: 161
Posted: March 28, 2004 at 2:52 PM / IP Logged
I installed a RS in a 2000 Chrysler LHS and the customer brought it back saying that when she starts it with the remote, the heat comes on but the blower doesn't until she turns it up or down a notch by hand. She says it works fine when started with the key. Any suggestions?
bmf1000d
Silver - Posts: 345
Posted: March 28, 2004 at 3:02 PM / IP Logged
Does it have the electric controls?
"Big" Mike
Double Take
Fremont, Ne
remember to check all your wires with a dmm not a test light!!
i take no responsibilty whatsoever for the vailidty of the info nor consequences thereof
Platinum - Posts: 12,488
Posted: March 28, 2004 at 4:28 PM / IP Logged
Did you power up both ACC & IGN wires ? I did one on another Chrysler and the electronic control module did the same thing and I ended up triple checking my wires and it ended up being a bad relay inside the unit that powered the ACC wire.
Memphisman
Copper - Posts: 161
Posted: March 29, 2004 at 7:36 AM / IP Logged
It has the electronic controls.
bmf1000d
Silver - Posts: 345
Posted: April 02, 2004 at 3:05 PM / IP Logged
Make sure you have all of the ACC and IGN wires hook up correctly. IF it still dones not power up then you have to send a pulse to the fan control switch telling it as thought you turned the control
"Big" Mike
Double Take
Fremont, Ne
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
