'02 Grand Cherokee Alarm Connections
vvreddy
Posted: August 19, 2002 at 6:17 PM / IP Logged
Hi,
I'm installing an alarm in my Laredo and I'm trying to figure out the wires for the interior lights(-) and the parking lights(+). If anyone can provide me the colors for the rear harness in the driver side kicker panel it would be much appreciated.
Thanks,
Vikram
Congo
Member - Posts: 9
Posted: August 19, 2002 at 8:08 PM / IP Logged
Jeep
Grand Cherokee
1999-2002
Remote Starter  Wiring Colors and Notes
Function
DTI Color
Vehicle  Color
Location
Start:
Yellow
YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
Blue
DK. BLUE
Ignition #2:
Green
BLACK/ ORANGE
Ignition  #3:
Wht/Blk
N/A
Accessory:
White
BLACK/ WHITE
Brake  Light:
Orange
WHITE/ TAN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
Green
Parking Lights:
Yellow
BLACK / YELLOW (-)
IN DRIVER'S KICK PANEL ****
Headlights:
Yellow
OEM Alarm  Disarm:
Brn/Wht
BLACK (-)
AT SWITCH IN DRIVER'S DOOR **
OEM Alarm  Arm:
n/a
Diesel  Glow Plug:
RED / Black
Clutch  Bypass Wire:
n/a
Notes:
 * This vehicle may be equipped with Chrysler's Smart Key Transponder Theft System Only If The Ignition Key Is Gray. See Installation Note #144 - Bypassing Transponder Theft Systems.
Jeep
Grand Cherokee
1999-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
DTI Color
Vehicle  Color
Location
Constant  +12 Volts:
Red
Starter  Kill:
Vlt or Wht
YELLOW
Ignition  +12 Volts:
Orange
DK. BLUE
Dome  Lights/Superv:
Brown
YELLOW (-)
3 PIN PLUG IN FUSE PANEL ON DR. SIDE
OEM Horn:
Blue
BLACK/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
Wht/Red
DRIVER/ ORANGE / VIOLET
PASSENGER/ BLACK/ WHITE ***
Power  Unlock:
Yel/Red
DRIVER/ PINK/BLACK
PASSENGER/ PINK/BLACK ***
Trunk  Release:
Grn/Wht
Alarm  Input Wire:
R/W or Gy/Bk
YELLOW (-)
Notes:
** This wire is located at the lock cylinder switch in the driver's door and is one of two coming of the switch. The correct wire will measure ground only when the door is unlocked using the key. *** See Note # 229 - Jeep Grand Cherokee Door Lock Diagram. **** The Parking Lights Are Activated By A Ground Pulse Through A 240 Ohm Resistor.
vvreddy
Posted: August 19, 2002 at 8:35 PM / IP Logged
Thanks for the quick info.
I hope I can find the three pin plug that is described for the dome light.
One problem I see is that my alarm has a positive output for the parking lights but this only lists a negative wire. Any idea what the positive wire would be?
vvreddy
Posted: August 20, 2002 at 10:08 AM / IP Logged
I can't find a three pin plug anywhere in the fuse panel as described for the dome light. Ideas? HELP!!!
Big Dog
Gold - Posts: 1,265
Posted: August 20, 2002 at 12:34 PM / IP Logged
Hey vvreddy,
For the door trigger wire, there are 4 separate door triggers wire, one for each door.  Use all 4 wires and diode isolate each together.  The drivers door is tan/red at the drivers door lock switch. The passenger door is tan/red at the passengers door lock switch.  The drivers rear door is tan/orange and the passengers rear door is tan / YELLOW at the BCM.
Also you cannot feed the positive wire because it's controlled by the BCM.  Use the negative as stated above.  Either way you'd be looking at the same work and you'd have to add a relay anyways.  '02 Grand Cherokee Alarm Connections -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
vvreddy
Posted: August 23, 2002 at 7:43 AM / IP Logged
Thanks for your help.
I managed to get everything working right. I was able to use the dome light wire for the trigger and that captures events for all doors and the trunk. Still need to use the relay and resistor to trigger the parking lights.
I also got the doorlock module for the Crime Guard 745i3 that reduces the number of wires that need to be connected to the vehicle from 7 to 1. So that was a great help and it also has driver priority unlocking.
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
