2002 Ram Quad RKE
bdit
Posted: March 29, 2004 at 7:21 PM / IP Logged
Has anyone had to install a remote start and the customer wanted to retain the 2 step door lock using the 785's remote. I'm trying to install and Audiovox APS785, the trucks has Keyless entry already installed, my problem is the wire color codes I have found for this are conflicting for drivers side lock. Or if anyone has done this already could you help me out with the wiring or maybe a diagram.
Here is what I have done so far I have found the blue wire for the Drivers side lock, cut it it does prevent the drivers door from locking or unlocking, but when I relay to it I still have no lock or unlock, Can'rt figure out what else i s happening when you hit the unlock on the factory remote
any help will be greatly appreciated
Thanks,
draasch
Gold - Posts: 2,172
Posted: March 29, 2004 at 7:49 PM / IP Logged
see if this info will help:
http://www.wiringinstructions.com/218.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
auex
Platinum - Posts: 5,041
Posted: March 29, 2004 at 8:56 PM / IP Logged
You need to five wire the driver's door unlock only on the first pulse to the progressive unlock, pin 85 +12V, pin 86 - first unlock pulse from alarm, pin 30 motor side of unlock wire, 87A switch side of unlock wire, 87 ground. Then wire the alarm's lock wire to the WHITE/ Green wire with a 820 ohm resistor, and wire the second unlock pulse through a 330 ohm resistor to the same wire, you may need relays for these wires. Check this link for relay pinouts.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
bdit
Posted: March 30, 2004 at 1:02 PM / IP Logged
Thanks for the input I still am unable to find the correct wire for the drivers doorlock only, can anyone point me in the right direction. Am i going to have to open it up in the door panel or will it pass back into thru drivers compartment? The wire I think it is, is blue and it comes off the white conn to the left of the steering column, this is also the location of the WHITE/ green and the lt GREEN/ orange disarm wire, but I see 2 wires that appear to have reversal when the unlock button is pressed9 The blue and tan/orange
not sure?
thaks
Wednesday, December 24, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
