530t window module to cs 2011 rs alarm?
jp cooper
Posted: April 08, 2004 at 5:40 PM / IP Logged
I have a crimestopper cs 2011 rs alarm and i want to install a 530t window automation system on it will it work and how do i wire it in?  Can some one help????
thanks,
JP Cooper
SoundImage
Copper - Posts: 75
Posted: April 08, 2004 at 7:50 PM / IP Logged
yes it will work just wire the window module.  then hook the orange wire to the orange off the alarm, but be sure to put a 1 amp diode between the starter relay and the alarm/moduale side.  The stripped side faces the alarm/moduale side. Then hook RED / wht to gray off the alrm for your down trigger.
jp cooper
Posted: April 09, 2004 at 10:46 AM / IP Logged
Thanks for the help.  Did i get the right window module for a dodge ram someone was telling me that the module must be able to handle a high current.
thanks,
JP Cooper
osokrayzay
Copper - Posts: 54
Posted: April 30, 2004 at 9:49 AM / IP Logged
Hello what year is this Dodge Ram?
I am having troubles getting the wire trough the door boot.
There is a plastic clip thats not letting anything pass.
My dodge ram is a 2003
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
