98 Chevy Z 28
golfnut64
Copper - Posts: 80
Posted: April 09, 2004 at 11:30 AM / IP Logged
Installed remote start in this & it worked fine untill this morning , Tryed to remote start it and set off the alarm , now it will not start with the key also it will not turn over at all. How do i reset this system Help
Lloyd
derek123
Copper - Posts: 163
Posted: April 09, 2004 at 12:01 PM / IP Logged
You mean it set off the Contents theft alarm ( horn honks when it tries to R.S.), or the Passlock 2 system ( just does not start) ?
this should help if the PL 2 is crashed:
Resetting the Passlock system on a Passlock 1 or 2 vehicle:
1 Turn the Ignition Key from the OFF position to the CRANK position ( the vehicle will not start as it is still locked, it will start and then stall ).
2 Leave the Ignition Key in the ON position.
3 The “Security” light will be flashing.
4 Wait for the “Security” light to turn OFF, ( up to 10 minutes)
5 Turn the Ignition Key from the ON position to the OFF position.
6 Wait approximately 10 seconds.
7 The system is now ready to re-learn the Passlock code, the next time the Ignition Key is turned from the OFF position to the CRANK position.
8 Turn the Ignition Key from the OFF position to the CRANK position, and start the vehicle.
9 The vehicle has now learned the Passlock code.
Note: Make sure the vehicle battery is fully charged before attempting this procedure.
golfnut64
Copper - Posts: 80
Posted: April 09, 2004 at 2:10 PM / IP Logged
Thanks got it to start with the key but now i have pass lock bypass disconected , The wire notes i have says the OEM alarm disarm is NA any one know if there is one & where it is   Thanks
Lloyd
