2003 silverado
chicomax75235
Copper - Posts: 70
Posted: April 15, 2004 at 11:32 PM / IP Logged
what  bypass modules would i need for a remote start?also what window module would work the best?Ived herd some will cut off due to heavy windows
Jose Chapa
chriswallace187
Gold - Posts: 1,661
Posted: April 16, 2004 at 12:54 AM / IP Logged
DEI's 555L bypass module and 530T window control module should work - if you already have power windows that is.
italnpimp59
Silver - Posts: 427
Posted: April 16, 2004 at 2:14 PM / IP Logged
u dont really even need a bypass for that truck since it is passlock 2.  cut the yellow passlock wire in half, and measure the resistance between the module side of that wire and the org/blk wire with the vehicle in reverse and the ebrake on.  put the key in start and let off, you will get a resistance value.  wire one relay like this:
85-ignition 3 output (-)
86-12volt constant
30-module side of yellow passlock wire with resistor on this wire
87- tap into org/blk wire
i always use this method rather than buying a bypass, passlock 2 is way easier than passlock 1, its pretty much impossible to bypass pass1 without a module!!
chicomax75235
Copper - Posts: 70
Posted: April 16, 2004 at 8:35 PM / IP Logged
ok so you need a resister ok but what window module would be the best?
Jose Chapa
extreme1
Silver - Posts: 1,070
Posted: April 16, 2004 at 9:13 PM / IP Logged
WinData from Trilogix is a databus based windows module for the 03 up GM vehicles
