2003 F-150 wiring
vikingeorge
Posted: April 24, 2004 at 11:23 AM / IP Logged
Can anyone tell me if the security wiring for a 2003 F-150 is the same as the wiring listed on this site for a 2000 Ford F series Security Information.
Thanks,Bryce
draasch
Gold - Posts: 2,172
Posted: April 24, 2004 at 8:07 PM / IP Logged
are you looking for the wiring info for the truck so you can do an install??
Make:   Ford
Model: Pickup - Fullsize
Year:    2003
This Database Was Last Updated On:    4/7/2004
Alarm
Constant 12 volts YELLOW & GREEN/ VIOLET IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE/L GREEN IGNITION SWITCH HARNESS
Starter RED / L BLUE IGNITION SWITCH HARNESS
Dome Light BLACK/ BLUE (+) DRIVERS & PASSENGERS KICK PANEL *
Trunk Pin Switch N/A
Parking Lamp BROWN / WHITE (+) HEADLIGHT SWITCH **
Power Lock PINK / YELLOW DRIVER KICK PANEL ABOVE *** #201
Power Unlock PINK/L GREEN PARKING BRAKE HANDLE #203
* Dome Light:(-) Pin Switch Wire Drivers BLACK / YELLOW All Others BLACK/ PINK Located In A 26 Pin Plug At The G.E.M. Above The Fuse Box. ** Parking Lamp Wire Also Located At Six Pin Connector Under Drivers Dash. *** W/ OEM Keyless Entry See Note #201.W/out OEM Keyless Entry See Note #203. #201 - See Negative Pulse Door Lock Diagram. (See Tech Notes) #203 - See Reversal Rest At Ground Door Lock Diagram.
Accessories
Window Up D\ WHT/BLK P\ TAN/BLU D\ YEL/BLU P\ RED / BLK @ MAIN #211
Window Down F/ ORG/WHT F/ WHT/YEL R/ GRY/ORG R/ YEL/BLK SWITCH
Ign Key Warn BLACK/ PINK (-) PLUG TO RIGHT OF STEERING COLUMN
Trunk Release N/A
OEM Horn D BLUE (-) PLUG TO RIGHT OF STEERING COLUMN
Headlights RED / YELLOW (+) AT HEADLIGHT SWITCH
OEM Alarm Arm
OEM Alarm Disarm GREEN/ VIOLET (-) AT G.E.M. ABOVE PARKING BRACKET
#211- See Reversal Rest At Ground Power Window Circuit Diagram. OEM Alarm Horn Wire- YELLOW/LT.GREEN At Fusebox Under Hood. OEM Alarm Hood Trigger- None Listed In Shop Manual.
Remote Start
Tach Signal D BLUE/L GREEN (4.2L) AT COIL PACK ON ENGINE * #239
Ignition #2 GRAY / YELLOW IGNITION SWITCH HARNESS
Ignition #3 RED / BLACK IGNITION SWITSH HARNESS
Accessory BLACK/ LIGHT GREEN IGNITION SWITCH HARNESS **
Neutral Safety NONE GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light L GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light BLACK/ PINK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost BLUE/ORANGE (-) AT SWITCH
* Wire Color Changes To L GREEN / WHITE On 4.6L and 5.3L Engines. ** Must Be Powered When Remote Started. #239- See Immobilizer Bypass Diagram. OEM Keyless ACC Wire: BLACK/ PINK At GEM Module Located Above The Fuse Box Fuse Box.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
