2004 Silverado lock/unlock
Little Bird
Posted: May 02, 2004 at 5:11 PM / IP Logged
Installing a CG 745i in my '04 Silverado LT 2500HD diesel crewcab.  Everything is connected and working except the door locks. Does anyone have wiring info (color / location) for this truck?  I am wanting to use driver door priority unlock.  The 745i has two internal relays and the wires are listed below.
Violet - Unlock (+) or (-) Input (NO)
Blue - Unlock Output (COM)
Brown - Unlock Input (NC)
Violet / Black - Lock (+) or (-) Input (NO)
Green / Black - Lock Output (COM)
White / Black - Lock Input (NC)
Pink - Unlock #2 250mA (-) Output
Thanks in advance!  Pat
profuse007
Gold - Posts: 2,015
Posted: May 02, 2004 at 7:38 PM / IP Logged
-i think the 03-04 are similar truck. on the based model truck, the lock wire is lt. blue (-) and unlock wire is white (-). They are in the lt. blue plug at the BCM. if not based model, look at the pdf
-so the wire above youll need:
-look at this pdf file
Houston,TX
