2003 Chevy Tahoe remote start
losone
Member - Posts: 37
Posted: May 06, 2004 at 12:52 AM / IP Logged
I have a 2003 tahoe that I just installed an autopage 850 with remote start .  The problem I have is that when I remote start it the abs & parking brake light come on until I use the key. The auto page only as 2 ignition outputs & one accessory wire, which I have connected to the pink ign 1, white ign 2 & the brown acc.
I believe I have a thrid ign which is orange, & being that that is not connected to the alarm could be why im getting the abs light?? The question I have is, IS this orange wire the ign 3 or another acc wire( ive seen it called both in other posts)??? And how should I connect it?? I've been told to use a relay & connect it to the ign 2 of the alarm, & also to connect it with a relay to the alarms acc wire, & autopage told me to use a diode & connect it to the ground when running wire going to the passlock bypass???
Im really confused as to how to finish this installation, what wires do you guys use on 2003 chevys???
rudbwoy69camaro
Silver - Posts: 350
Posted: May 06, 2004 at 8:56 AM / IP Logged
2003 Chevrolet Tahoe
ItemWire ColorPolarityWire Location
12Vred & RED / white+ignition harness
STARTERyellow+ignition harness
IGNITIONpink+ignition harness
ACCESSORYorange+ignition harness
SECOND ACCESSORYwhite+ignition harness
TACHOMETERNOT pinkany fuel injector
POWER LOCKuse Directed module
POWER UNLOCKpart #456G *3
PARKING LIGHTS +browndriver kick panel
PARKING LIGHTS -gray/blackheadlight switch
DOOR TRIGGER*1-*1
HEADLIGHTSpink or white-headlight switch
WIPERS
LF WINDOW UP/DNblue - brownALF window switch in door
RF WINDOW UP/DNlt. blue - tanARF window switch in door
LR WINDOW UP/DNblue - brownALR window switch in door
RR WINDOW UP/DNblue - brownARR window switch in door
TRUNK/HATCH PINpink/black-harness to BCM *2
HOOD PIN
TRUNK/HATCH RELEASE
FACTORY ALARM ARM
FACTORY ALARM DISARMlt. green-driver door module in door
HORN TRIGGERblack or blk/yel-column or gray plug @ BCM *2
BRAKE WIREwhite+brake pedal switch
LOCK MOTORgraydriver door module in door
UNLOCK MOTORtandriver door module in door
DISARM DEFEATtandriver rear door harness
DISARM NO UNLOCKnone
DOME SUPERVISIONcomes on with disarm
SPEED SENSE
SUN ROOF OPEN/CLOSE
SUN ROOF LIMIT
LF SPEAKER
RF SPEAKER
LR SPEAKER
RR SPEAKER
RADIO 12V
RADIO GROUND
RADIO SWITCH
RADIO ILLUMINATE
POWER ANTENNA
Notes:NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black and the RR is lt. GREEN/ black, they are in a harness in front of the fusebox leading to the BCM rear plug. Use all four wires and diode isolate each. *2 The BCM (Body Control Module) is located behind the headlight switch. *3 If Directed module part #456G is not available, refer to directfax document #1601. Upper trim level vehicles may have a door lock switch on the right rear panel. If present use white (-) for lock and lt. blue (-) for unlock.
rudbwoy69camaro
Silver - Posts: 350
Posted: May 06, 2004 at 9:03 AM / IP Logged
What transponder bypass are you using?
autopage told you right, check out the relays page(s) here on 12volt:
https://www.the12volt.com/installbay/forum_topics.asp?fid=5
https://www.the12volt.com/relays/page5.asp
Look for this at the bottom of the page too:
Relays:
Converting Polarity
Starter Interrupts
Door Locks
Illuminated Entry & Light Flash
Special Applications
losone
Member - Posts: 37
Posted: May 06, 2004 at 10:59 AM / IP Logged
Im using the passlock unit from crimestopper. All that seems to be working fine.  So your saying rather than splitting one of the ignition ouputs from the alarm  with a relay, to use the ground while running output from the alarm.  Since I beleive this is a negative output, does it need to be converted to positive to power the extra ignition/acc wire??
profuse007
Gold - Posts: 2,015
Posted: May 06, 2004 at 11:05 AM / IP Logged
yep, since all ACCs/IGNs are isolated, lets keep 'em that way and use another relay to power it up.
Houston,TX
sexyvic1
Copper - Posts: 144
Posted: May 16, 2004 at 12:53 AM / IP Logged
just wanted to know how the install went.. i will be puting the same alarm in my 2001 tahoe. do u have any tips for me? any sites with wiring diagrams? please help and reply. thanks.
profuse007
Gold - Posts: 2,015
Posted: May 16, 2004 at 3:33 AM / IP Logged
www.7thgencivic.com has Directtech diagram which are pretty detailed. need to sign up for the site, its free.
Houston,TX
NowYaKnow
Gold - Posts: 1,217
Posted: May 16, 2004 at 10:37 AM / IP Logged
A little late, but you need to fire up the pink with ignition 1, the white with ignition 2, and the orange with accessory 1. You don't need the brown 99% of the time. If you power up the previous wires and still have problems turn on the brown as accessory 2 using 2 relays off of the accessory 1.
Mike
superfly
Member - Posts: 10
Posted: May 18, 2004 at 6:40 PM / IP Logged
A little word of advice to add, check to make sure there are not 3 ign wires, if it does it will have 2 pinks and 1 white, the small 18 gauge pink wire must be powered up or damage to the vehicles transmission will occur, this wire powers the computer for the transmission and it doesnt like it when the vehicle is running and there is no power on this wire.  This wire is usually just to the right of one of the red 12 volt constant wires in the steering column harness connector.
Chris
Check twice, install once. Superfly
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
