99 ram 2500 diesel
godsegoizhuge
Copper - Posts: 214
Posted: May 10, 2004 at 11:47 PM / IP Logged
Could someone please send me the wiring info on this vehicle? i looked in the vehicle database but couldn't find the info on this truck.
jfk51502003
Copper - Posts: 221
Posted: May 11, 2004 at 9:51 AM / IP Logged
12volts red and pink/black   +  ignition harness
Starter yellow   +  ignition harness
Second Starter
Ignition dk. blue   +  ignition harness
Second Ignition BLACK/ orange   +  ignition harness
Third Ignition
Accessory BLACK/ white   +  ignition harness
Second Accessory
Keysense
Power Lock ORANGE / purple  5wi driver door harness
Notes: Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.
Power Unlock pink/purple  5wi driver door harness
Lock Motor
Unlock Motor
Parking Lights+ BLACK / YELLOW    drivers kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow   -  drivers kick panel
Notes: To avoid dome delay, use tan for the drivers door and BLACK/ lt. blue for the passenger door. Both wires are located at the central timer module to the right side of the steering column. Use both wires and diode isolate each.
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Notes: Must see a ground on the tan drivers door trigger wire while locking to arm the factory alarm. This only works if the vehicle does not have delayed domelight.
Factory Alarm Disarm lt. GREEN/ orange   -  harness from door
Disarm No Unlock
Tachometer BLACK/ gray    ignition coil
Notes: Diesel tach wire is gray/black and diesel wait to start wire is ORANGE / black (-) see direct fax document #1090. Both wires are located on the center of the firewall. There are two black plugs, the wires are in the top plug without the white insert. The tach wire can also be found at the ECM on the passenger side firewall in connector C-1, pin 8.
Wait to start
Brake Wire WHITE/ tan   +  at brake pedal switch
Parking Brake
Horn Trigger BLACK/ red   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
99 ram 2500 diesel -- posted image.
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance
