trunk pin switch
marvel
Member - Posts: 23
Posted: May 18, 2004 at 7:42 AM / IP Logged
hi guys.
can somebody pls tell me what for is the trunk pin switch wire colored RED / White (-) at the trunk area. And also why are there 2 wires for ignition: IGNITION 1  BLACK/ Red : IGNITION 2 BLACK / YELLOW
car: camry 2000 LE
thanks
turbo
profuse007
Gold - Posts: 2,015
Posted: May 18, 2004 at 1:52 PM / IP Logged
|     DOOR TRIGGER|RED / white           |- |top of fuse box *5          |
| TRUNK/HATCH PIN|RED / yellow          |- |light or sw. in trunk       |
thats not trunk pin/trigger, its the door trigger/pin.
|        IGNITION|BLACK / YELLOW        |+ |ignition harness            |
| SECOND IGNITION|BLACK/ red *1        |+ |ignition harness            |
There are two BLACK/ red wires going to the same pin at the plug. use either one.
ignition is for ignition, and second ignition could be for ur ac/blower
Houston,TX
marvel
Member - Posts: 23
Posted: May 19, 2004 at 6:08 AM / IP Logged
thanks profuse007
turbo
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
