Parking Lights are Staying on all the time
supersi99
Member - Posts: 13
Posted: May 26, 2004 at 5:09 PM / IP Logged
I need to help this guy with an older Isuzu Trooper and an autopage alarm His parking lights just started to stey on all the time so i just disconnected the brain for him real quick so his battery doesnt die but  he asked me to fix it for him over the weekend. Could the plug just have been loose or maybe a short in the wire? Where should I look first and what would cause thhappen all of a sudden
Scott
draasch
Gold - Posts: 2,172
Posted: May 26, 2004 at 5:12 PM / IP Logged
did the lights go off after you d/c the brain???
if so the problem may be inside the unit....
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Platinum - Posts: 12,488
Posted: May 26, 2004 at 6:08 PM / IP Logged
Try to disconnect the parking light output from the RS and see if this persists. If it does, then it's not the RS.
supersi99
Member - Posts: 13
Posted: May 26, 2004 at 6:42 PM / IP Logged
After I disconnected the brain the lights went off you think the brain is shot?
Posted: May 26, 2004 at 8:31 PM / IP Logged
Sounds like the internal relay for the CPU is shot.
sparkie
Platinum - Posts: 2,061
Posted: May 26, 2004 at 9:35 PM / IP Logged
The problem is likely due to carbon build up on the parking light relay's contacts. They tend to stick closed after a number of years. Try replacing the realy in the module either by desoldering it off the board and installing a new one or wiring an outboard relay controlled by a wire soldered onto the module's circuit board. Don't try cleaning the old relay as this is only a temporary fix at best.
sparky
supersi99
Member - Posts: 13
Posted: May 27, 2004 at 6:57 PM / IP Logged
thanks guys ill try it this weekend
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
