2002 rav4 door locks
xtreamvette
Posted: May 30, 2004 at 1:29 AM / IP Logged
hey all i am in need of some help with my keyless entry on a 2002 rav4. it seems that no matter how i try to wire them they wont work properly. let me explain......they are all hooked up properly and work great, until the vehicle sets for a few minites than it will respond to the unlock command only by chirping and flashing the lights but the doors do not unlock, unless i remote start it than try the unlock and it will work???? almost seems as if the unlock circuite goes into hybernation......has anyone got any ideas? please respond asap this has me pulling my hair out this is the second system i have tried. and yes i have tried double pulse, single pulse , almost everything. lmk thanks in advance.......
draasch
Gold - Posts: 2,172
Posted: May 30, 2004 at 10:24 AM / IP Logged
we need to know what unit you are using....
here is what i have for that car:
Power Lock:
   Blu/Org or Wht/Grn
DRIVER'S KICK PANEL **
Power Unlock:
   Blu/Yel or Wht/Blu
DOUBLE PULSE UNLOCK**
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
JWorm
Platinum - Posts: 2,208
Posted: May 30, 2004 at 11:56 AM / IP Logged
The doorlock wires that go to the switch on the door fall asleep after a few minutes. The wires that go to the key cylinder don't.
I have the colors as:
Power Lock      blue/orange        -       DKP, 14 pin plug in pin 6
Power Unlock      blue / YELLOW        -       DKP, 14 pin plug in pin 13
Notes: Unlock requires a double pulse. You need to meter them while turning the key in the door.
profuse007
Gold - Posts: 2,015
Posted: May 30, 2004 at 4:25 PM / IP Logged
i used the wire at the drivers kick and it works out great for couple of months now, never had my friend callin me back for any problem.
i used single pulse as a progressive unlocking.
unlock once- driver
unlock second time-all the other doors.
Houston,TX
