Checking the aux output on alarm brain
NINsane18
Copper - Posts: 103
Posted: May 30, 2004 at 11:12 PM / IP Logged
Hey all, I have an add-on Crimestopper RS901 remote start going to my Crimeguard alarm on a 1998 Jeep Grand Cherokee without the transponder key system. I am using the second channel - output to trigger the remote start. When I trigger the second channel, the remote start does nothing. I picked up the remote start for next to nothing off of Ebay, and the seller is no longer a registered user when I tried to contact them about warranty, so can I test my - output by putting my ground lead of my dmm to the wire, and the + lead to 12v+ and look for a reading when the second channel is activated to rule out the alarm brain? All connections have been soldered, and checked via a dmm. Thanks!!
Tim-May!
jrilla
Gold - Posts: 1,498
Posted: May 30, 2004 at 11:38 PM / IP Logged
One way to test the output is to hook it up to an extra relay if you have one to see if it triggers the relay.
J Rilla
Owner/Installer
iskidoo
Silver - Posts: 1,046
Posted: May 31, 2004 at 11:38 PM / IP Logged
NINsane18 wrote:
so can I test my - output by putting my ground lead of my dmm to the wire, and the + lead to 12v+ and look for a reading when the second channel is activated?
Exactly, or a test light clipped to the wire and the other end to +12 volts.
Or to test the add-on starter, just touch the negative start activation wire to chassis ground for a moment to see if it triggers.
Friday, November 7, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
