wire diagrams for 04 park ave and avalanc
ranquist
Member - Posts: 36
Posted: June 01, 2004 at 3:52 PM / IP Logged
Hi all, looking for up-to-date wiring for 04 park ave and avalanch. Thanx
jfk51502003
Copper - Posts: 221
Posted: June 05, 2004 at 3:28 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / AVALANCHE / 2004 / Remote Start
[PRINT THIS PAGE]
12voltsred & RED / white + ignition harness
Starteryellow + ignition harness
Second StarterN/A
Ignitionpink + ignition harness
Second Ignitionwhite + ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third IgnitionN/A
Accessoryorange + ignition harness
Second Accessorybrown + ignition harness
Keysenselt. green - ignition harness
Power Lockuse Directed module 456G
Notes: If Directed module 456G is not available, refer to DirectFax document 1601.
Power Unlocksee power lock
Lock Motorgray driver door module in door
Unlock Motortan driver door module in door
Parking Lights+brown + driver kick panel
Parking Lights-gray/black - switch or BCM, brown plug pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazardswhite - steering column
Turn Signal(L)green + steering column
Turn Signal(R)lt. green + steering column
Reverse Lightlt. green + BCM, black plug, pin F
Door Triggersee notes - see notes
Notes: The driver door trigger is gray/black at the driver door module in the door. The RF door trigger is BLACK/ white at the passenger door module in the door. The LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2, they are in the purple plug at the BCM. Use all four wires and diode isolate each.
Dome Supervisiongray/black + BCM, black plug, pin E
Trunk/Hatch PinN/A
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armarms with lock
Factory Alarm Disarmlt. green - driver door module in door
Disarm No Unlocksee factory alarm disarm
Tachometerwhite ac instrument cluster or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to startN/A
Brake Wirewhite + brake pedal switch
Parking Brakelt. blue - switch or BCM, lt. blu plug, pin A7
Horn TriggerBLACK / YELLOW to black - column or BCM, gray plug, pin B9
Memory Seat 1red + driver door module in door
Memory Seat 2pink + driver door module in door
Memory Seat 3N/A +
Immobilizer Bypass Module:Required: YesType: Passlock 2Part #: 555L or 555T
Notes: The Passlock 2 wire colors are yellow, black (org/blk), and RED / white (not used).
wire diagrams for 04 park ave and avalanc -- posted image.
ka3vvv
Copper - Posts: 47
Posted: June 26, 2004 at 10:47 PM / IP Logged
would this be the same for a 2003 GMC YUKON.
I have my check engine light on never had this befor . But I also have a service 4 wheel light on. took to dealer for that it. It bad module in have a leak in the case. This happen befor check engine light.
