1996 Explorer XLT alarm
nava94
Silver - Posts: 296
Posted: June 03, 2004 at 10:11 PM / IP Logged
Hey guyz I have a 96 Explorer XLT with a factory alarm installed aftermarket alarm bcuz I did not get the original remotes for the factory alarm. I got each door trigger and isolated them with diodes so the BCM would not trigger the alarm when it times out but every hour once the aftermarket alarm is armed it goes off. Does anyone have a diagram to bypass this problem.Thanks.
draasch
Gold - Posts: 2,172
Posted: June 03, 2004 at 11:01 PM / IP Logged
OEM Alarm Arm N/A
OEM Alarm Disarm D GREEN/ PURPLE (-) IN 55 PIN CONN. IN DR. KICK PANEL
www.keylessride.com
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
nava94
Silver - Posts: 296
Posted: June 04, 2004 at 11:42 PM / IP Logged
I  used the aftermarket alarm to disarm the factory alarm. the thimg now is the aftk. alarm goes of every hour and with both the aftk. & factory alarm armed they go off every half hour. the bcm sends a signal thru the door triggers to check the status off the doors before it times out. does anyone have a diagram or tech soft to bypass this.thankz.
jfk51502003
Copper - Posts: 221
Posted: June 05, 2004 at 10:13 AM / IP Logged
if you used diodes how is it the door trigger...maybe something else...diodes in right direction...?
jfk51502003
Copper - Posts: 221
Posted: June 05, 2004 at 10:16 AM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - FORD / EXPLORER / 1996 / Security
[PRINT THIS PAGE]
12voltsyellow + ignition harness
StarterRED / lt. blue + ignition harness
IgnitionGREEN/ purple + ignition harness
Notes: Two wires each at switch, both are common, only need to power 1 each during remote start.
Power Lockpink / YELLOW - driver kick panel
Power Unlockpink/green - driver kick panel
Lock Motorpink/black  driver kick panel
Unlock MotorRED / orange  driver kick panel
Disarm Defeatpink/orange  driver kick panel
Notes: You may also use the pink/green power unlock wire.
Parking Lights+PURPLE / white  driver kick panel
Notes: Also found to be WHITE/ black at the rear of the switch.
Parking Lights-WHITE/ purple  driver kick panel
Hazards
Turn Signal(L)
Turn Signal(R)
Door TriggerBLACK/ lt. blue + driver kick panel
Notes: To avoid the dome light delay and dome light time-out use the separate door triggers. In the drivers kick panel find yellow/black for the drivers door, lt. GREEN/ YELLOW for the drivers rear door, and WHITE/ purple for the rear hatch. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All five wires are negative trigger and must be diode isolated together.
Dome SupervisionBLACK/ lt.blue + driver kick panel
Trunk/Hatch Pincommon with doors
Hood Pintan/lt.green - driver kick panel
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Armarms on lock
Notes: Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm.
Factory Alarm Disarmdk. GREEN/ purple - driver kick panel
Disarm No Unlock
Tachometertan / YELLOW AC PCM
Notes: The PCM is located at the top of the firewall towards the passenger side, the tan / YELLOW tach wire is also found at the back of the instrument cluster.
Horn Triggeryellow/lt. green - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
1996 Explorer XLT alarm -- posted image.
Immobilizer Bypass Module:Required: YesType: PATSPart #: 555F or 555U
Notes: N/A
onlyremotes
Member - Posts: 21
Posted: June 05, 2004 at 10:44 PM / IP Logged
what alarm brand and model are you using?
Walton Guerrero-Installer/Distributor
Alltech Electronics,Inc
3732 Grissom Lane
Kissimmee, Florida 34741
autotechs.com onlyremotes.com
1-888-252-8324
"Always check your wires with a multimeter"
nava94
Silver - Posts: 296
Posted: June 06, 2004 at 11:48 PM / IP Logged
It's a black widow bwi800. figured out the set up have to use a relay 85,12v. 86 door triggers from vehicle, 30 ground, & 87 neg. trigger of alarm. the vehicles bcm times out just like the Dodge Ram Trucks. Since I grabbed the individual door triggers I dioded isolated them now I need the relay to stop the alarm from falsing. Thankz guyz.
spl-Hz
Copper - Posts: 94
Posted: June 19, 2004 at 11:42 PM / IP Logged
try 210mf cap to stop impulse that might be coming from bcm shut down
