Honda civic 93 horn relay
Theshark
Posted: June 04, 2004 at 12:24 PM / IP Logged
I've tried to connect the blue/red wire to a relay to my alarm system... but it doesnt work.. what am I doing wrong? Help me...
deviousjoker
Copper - Posts: 102
Posted: June 04, 2004 at 1:41 PM / IP Logged
how exactly did you try to wire it.........does your alarm have an output for a horn?.......what kind of alarm is it?
First Class MECP Installer
profuse007
Gold - Posts: 2,015
Posted: June 04, 2004 at 2:18 PM / IP Logged
do it this way w/ a relay:
85-ground
86-siren wire from the alarm
30-ground
87-blue/red
this should work, unless youre loookin at the wrong one. check the wire b4 tappin it in.
Houston,TX
Theshark
Posted: June 04, 2004 at 4:15 PM / IP Logged
I have the good wire thats for sure because when I disconnect it, no more horn!
Lets say I connect a 12v lead on the blue/red wire, should horn right? Well it doesnt!
Any impulsion or whatever current I send to the blue/red doesnt make a thing!
profuse007
Gold - Posts: 2,015
Posted: June 04, 2004 at 7:09 PM / IP Logged
hmm...no!!! thats gonna short out ur horn.....
-the blue/red is negative(-)
Houston,TX
Theshark
Posted: June 04, 2004 at 7:15 PM / IP Logged
Than what should I do?=/
profuse007
Gold - Posts: 2,015
Posted: June 04, 2004 at 7:51 PM / IP Logged
hmm..... whats goin on w/ ur horn now? does it still work?
if it does, then use the diagram i listed aboved.
Houston,TX
Theshark
Posted: June 04, 2004 at 9:24 PM / IP Logged
Yap the horn still works but my problem is :
I want the horn to honk when it receives the signal to do it, but another one then the one on the steering wheel..
