01 Tacoma 4 Dr car alarm install
Posted: June 08, 2004 at 9:53 PM / IP Logged
Need help for my install... I've done all wiring for a Code Alarm CSI300 except the Door trigger and Lock/Unlock connections. Can anyone help with specific details?
1. Can I connect the door trigger to just one door pin switch for all 4 doors because I can't locate the suggested GREEN / WHITE?
2. the wiring diagram for my truck (from this web site) states the power lock wire as RED / White but I can't find it. I think it's Blue Black, does anyone know?
draasch
Gold - Posts: 2,172
Posted: June 10, 2004 at 9:07 AM / IP Logged
Dome Light BLACK/ WHITE (-) 12 PIN CONN ON BACK OF FUSE BOX *
* Also Found As BLACK/ WHITE (-) In 3 Pin Conn. High In Dr Kick Panel
Power Lock BLACK/ BLUE 12 PIN CONNECTOR IN #209
Power Unlock RED / YELLOW DRIVER KICK PANEL ***
*** Child Safety Locks:GREEN/ BLACK In 12 Same Connector As Door Lock Unlock Wires. #209 - See Child Safety Door Lock Diagram.
http://wiringinstructions.com/209.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
