Viper 791xv problem
egleas84
Member - Posts: 7
Posted: June 12, 2004 at 5:19 PM / IP Logged
Here's the deal.  Got it off ebay.  Installed it myself, everything works great, locks, alarm.  however the remote start isnt working...   the remote transmits the signal, and then nothing happends.  the car starts with key, and i rechecked the wire connections on my 01 dodge stratus sedan. i dont understand it, ive installed an rs before and ive never seen one liek this.  the relays dont make any noise either.  i figure i missed a wire or something.  any idea's?  i need help.  :(
dont wiz on the electric fence
draasch
Gold - Posts: 2,172
Posted: June 12, 2004 at 5:34 PM / IP Logged
* If Ignition Key Is GREY-Vehicle Has Immobilizer, If Ignition Key is Black-Vehicle Does Not Have Immobilizer. #239-See Immobilizer By-Pass Circuit Diagram
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
padawan
Copper - Posts: 215
Tach, ignition wires, bypass module...Check those things.
egleas84
Member - Posts: 7
Posted: June 12, 2004 at 6:17 PM / IP Logged
does the tach wire have to be hooked up?  i didnt do it i figured it could run tachless.  what bypass module?  and no i do not have have the grey key
draasch
Gold - Posts: 2,172
Posted: June 12, 2004 at 6:58 PM / IP Logged
if its not even powering up the ign at all, then you may not have the safety neutral wire hooked up. there most likely a wire that should see a ground in order for the remote start to work.
Good Luck
David
Ace Security
813-376-9778
Tampa
egleas84
Member - Posts: 7
Posted: June 12, 2004 at 7:35 PM / IP Logged
i in fact did not hook up that wire.  would that cause it?  the ignition does not power up at all.  so i should ground that wire?
draasch
Gold - Posts: 2,172
Posted: June 12, 2004 at 7:58 PM / IP Logged
yes most systems will operate unless it is hooked up. it would be the same thing as leaving the car in gear. the remote start will work because it thinks the car will take off. post your findings.......
Good Luck
David
Ace Security
813-376-9778
Tampa
egleas84
Member - Posts: 7
Posted: June 12, 2004 at 8:19 PM / IP Logged
that wire did the trick!  but now i have discovered i need to use the tach wire.  but i dont know what it looks like on my car! haha, but the start system works now.  thanks guys. all because of a neutral safety input wire.
draasch
Gold - Posts: 2,172
Posted: June 12, 2004 at 8:27 PM / IP Logged
try to reprogram the unit....it may not have programmed because of that wire..............
Good Luck
David
Ace Security
813-376-9778
Tampa
Sunday, July 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
