where - 98 toyota corolla dome light wire
zoink
Member - Posts: 7
Posted: June 19, 2004 at 1:50 PM / IP Logged
Hey guys,
Which wire and where can I find the dome light wire in my 98 corolla so I can hook up my alarm for surveillance output ?
thanks,
Zoink.
draasch
Gold - Posts: 2,172
Posted: June 19, 2004 at 1:56 PM / IP Logged
Dome Light RED / WHITE (-) IGNITION SWITCH HARNESS *
* RED / WHITE (-) Wire Listed For The Dome Light Is Located At The Key Cylinder Switch. This Circuit Illuminates The Key Cylinder Switch.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
zoink
Member - Posts: 7
Posted: June 21, 2004 at 5:01 PM / IP Logged
thanks for the help. I'll hook it up this coming weekend.
Zoink ! where - 98 toyota corolla dome light wire -- posted image.
dei user
Member - Posts: 44
Posted: June 22, 2004 at 6:17 PM / IP Logged
also found on left panel going down against the front window
dei user
zoink
Member - Posts: 7
Posted: June 23, 2004 at 12:41 PM / IP Logged
Thanks, I assume its RED / WHITE (-) also as what David says ?
