alarm/airbag interface
blckmajk00
Posted: June 19, 2004 at 10:25 PM / IP Logged
i've been driving myself crazy trying to find an alarm that could work with my bags so that when i arm the alarm, my car lowers. I already have the let-out valves on the bags, so im not worried about my car slaming down, just a nice slow drop till im basically sitting on my rims. Making it impossible to get them out. if any one could help me id be greatly appriciative.
2000 monte carlo ss, slp headers, slp cai, series 40 flowmasters, sony head unit, kicker impulse 250 & 180 amps, two kicker comp vr 12", air bag suspension, 20" pacer zr-12 wheels
auex
Platinum - Posts: 5,041
Posted: June 20, 2004 at 12:47 AM / IP Logged
There are two ways to do it. First, wire a relay to an accessory output of the alarm and using diodes ,probably six amp, wire the relay to the deflate inputs on the solenoids, this way you would manually have to push a button to lower. Second way would be to buy a pulse timer, set it to like 10 seconds, and wire it ground when armed and wire the relay/diodes the same manor as option 1, this way it would go down on it's own when arming the alarm.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
