3 wire negative locks
gpgtp00
Copper - Posts: 81
Posted: September 08, 2002 at 6:30 PM / IP Logged
I know this is probably a repeat question, but im not real sure on this. I have onboard relays for the door lock setup. I dont undertand what it means to have NO (normally open) or NC (norm. closed) ?? I have one of each for the unlock and lock. How do i know which one i use? Thanks ~Ed
mobiletoys2002
Gold - Posts: 1,050
Posted: September 08, 2002 at 6:53 PM / IP Logged
if you are familiar with a regular spdt relay than this will be verry easy but i assume you are not. So here goes the normally open contact will be pin 87 of a normal relay, the normal closed will be pin 87a. Now what kind of car do you have an then i can put up a diagram if you need it .
Chris Luongo
Platinum - Posts: 3,746
Posted: September 08, 2002 at 8:05 PM / IP Logged
What kind of car is it?
gpgtp00
Copper - Posts: 81
Posted: September 08, 2002 at 9:13 PM / IP Logged
2000 Grand prix. i have the Clifford AvantGuard 4. Also, if any of you are familiar with a MAS Window Roll-up Module, that would be great. I dont understand what the orange "acc. item" wire is and what the "activation" wire is. I wanna say that the activation is what im gonna hook the alarm output too, but then that still leaves orange "acc. wire" Thanks
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
