DEI 555l Installation
sictruck
Member - Posts: 22
Posted: June 24, 2004 at 2:19 PM / IP Logged
what wires do i hook the pink wire and blue/black wire from the 555l to?  i have a solaris alarm.
profuse007
Gold - Posts: 2,015
Posted: June 25, 2004 at 2:17 AM / IP Logged
what is the pink and blue/black wire called?
Houston,TX
dalmyd1
Member - Posts: 27
Posted: June 25, 2004 at 2:20 AM / IP Logged
The pink wire goes to your true ignition & the blue/black goes to your (-)200m output of your alarm....Hope this helps!!!!!!!!!
sictruck
Member - Posts: 22
Posted: June 26, 2004 at 9:13 PM / IP Logged
sorry let me be more specific.  the blue/black wire from the 555l which is status input wire, where does it go to?  the - out when started, or - pulse out after remote start, or - pulse out before remote start.  which one?  and does the pink wire, ingition input go to key side ignition input, or starter side output?
profuse007
Gold - Posts: 2,015
Posted: June 26, 2004 at 9:27 PM / IP Logged
status input- ingnition 3(-), status(-). look at ur alarm to see if it has it. any wire that pulse (-) when remote start or right b4 remtoe start.
the pink wire- if says to the ignition side, then youre suppose to cut a wire at the transponder ring (locate at the key cylinder). theres suppose to be two wire, pink and something that goes each end.
i hope you know what i mean.
look at the diagram, and youll see that one of the wire is being cut. it specify which wire goes which, keyside of igniton side.
Houston,TX
