code alarm ca 120
Raul Puente
Member - Posts: 23
Posted: June 27, 2004 at 11:42 AM / IP Logged
this is my first time installing this alarm
what i was wondering is that coming from the
alarm there are six wires for the lock/unlock  how would i go about
installing them on a basic car to unlock/lock the doors.
thanks
swamprat323
Gold - Posts: 1,335
Posted: June 27, 2004 at 12:01 PM / IP Logged
What kind of lock system do you have? What kind if car do you have?
swamprat323
Gold - Posts: 1,335
Double post
Raul Puente
Member - Posts: 23
Posted: June 27, 2004 at 12:25 PM / IP Logged
the car is a pontiac grand am 2002
swamprat323
Gold - Posts: 1,335
Posted: June 27, 2004 at 1:14 PM / IP Logged
POWER LOCK|white               |- |drivers kick panel in          POWER UNLOCK|same wire           |*2 |a black plug
*2 Lock requires a negative trigger, and unlock requires a negative trigger through a 1,500 ohm resistor. Must use relays. Must close doors to lock with a single pulse.
Green with 1,500 ohm ressitor to lock/unlock wire.
Blue to lock/unlock wire
GREEN/ black to ground
Blue/Black to ground
Raul Puente
Member - Posts: 23
Posted: June 27, 2004 at 1:24 PM / IP Logged
ok what about the grn/red wire and the blue/red from the alarm
swamprat323
Gold - Posts: 1,335
Posted: June 27, 2004 at 1:28 PM / IP Logged
They wont be used. You may have to have the door closed b4 it will lock, not sure on a 2002 but it that way for a 2003
Raul Puente
Member - Posts: 23
Posted: June 27, 2004 at 1:38 PM / IP Logged
what are those wires mainly used for are they for changing the polarity from pos; to neg;
or the other way around.
swamprat323
Gold - Posts: 1,335
Posted: June 27, 2004 at 1:39 PM / IP Logged
Sorry about this but made a mistake use the
GREEN/ red to ground
blue/red to ground
Dont use GREEN/ black and blue/black
Raul Puente
Member - Posts: 23
Posted: June 27, 2004 at 1:46 PM / IP Logged
so what your say is that to get pos conncet those wires to 12volts
and to get neg conncet to ground also what are those wires  grn/blk
and blu/blk used for?
Sunday, July 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
