96 F350 Remote Start Question
69crewcab
Posted: July 11, 2004 at 10:45 AM / IP Logged
I have installed a Crimestopper Remote Start Alarm system, but can't get the accesories (A/C) to work when the rmote start is used. I hooked up the accesory wire from the m to the grey / YELLOW wire at the steering column and the fan comes on, but the A/C clutch doesn't engage. (And yes, I have the switch turned to A/C). On this site it says the wire to turn on the a/c & heater the accessoriy wire fromthe alarm should go to a blue/green wire at the steering column, but wire is like a 24 gauge wire and doesn't do anything when I connected to it, in addition, it only has 6VDC when the igntion switch is turned to on.
Any help would be much appreciated.
jfk51502003
Copper - Posts: 221
Posted: July 11, 2004 at 11:21 AM / IP Logged
Accessory gry/yel & blk/grn   +  ignition harness
Second Accessory gray / YELLOW 18awg   +  ignition harness
THIS SHOULD HELP...!!!
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
