Aftermarket power door lock (with picture!)
SDRandy
Member - Posts: 15
Posted: September 12, 2002 at 9:41 PM / IP Logged
Hi guys,
I am trying to get the actuator to work properly, but I am having some problems.
Here is the digram I am using:   https://www.the12volt.com/doorlocks/page3.asp#arp
Here is a picture of my setup, i know its ugly and not very clear, but I hope it is just something really obvious that I am missing:
Aftermarket power door lock (with picture!) -- posted image.
When the fuse is not in, and I touch the wires labeled 86 or 85 to the +12volt, i hear the corresponding relay click.  But, when i try to put the fuse in sparks fly everywhere and it burns out the fuse.  Of course, without the fuse, the actuators dont do anything.
The actuators work fine, because when i hook one wire up to the neg terminal of the battery and touch the other to the pos. it moves up or down (depending on configuration).  Note that the relay's are upside-down in this picture when compared to the wiring diagram on this site.
Any and ALL suggestions are appreciated!!  Thanks everyone!
-randy
Platinum - Posts: 12,488
Posted: September 12, 2002 at 9:46 PM / IP Logged
85 & 86 require a (-) input in order for the relays to work. Try this and make sure that your alarm or keyless entry is set to output (-) not (+).
gpgtp00
Copper - Posts: 81
Posted: September 12, 2002 at 9:48 PM / IP Logged
what kind of alarm are you hooking this up to?
go2pac
Copper - Posts: 179
Posted: September 12, 2002 at 10:13 PM / IP Logged
What kind of relays are those? If they are not SPDT relays but of some other design then that would be your problem. I notice that the tab is not on the side which should be terminal #30. I have a feeling that what should be terminal 87A and 87, might be internally connected  together.
Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
SDRandy
Member - Posts: 15
Posted: September 13, 2002 at 1:47 PM / IP Logged
Im actually not using a keyless entry or alarm system...  I just want to have a button on my door which will let me lock and unlock the front two doors...
These are SPDT relays.  Like I said, they are upside down in the picture.
The issue is this:  Even when pins 85 and 86 arent hooked up to - or +, i cannot put the fuse in.  It will blow as soon as i put it in.
Do pins 85 and 86 labeled as needing to be hooked up to "alarm (-) " on https://www.the12volt.com/doorlocks/page3.asp#arp need to be hooked up to something before i can put in the fuse?
I appreciate all of your comments and suggestions.
go2pac
Copper - Posts: 179
Posted: September 14, 2002 at 12:23 AM / IP Logged
I see that they are upside down, but i also see that the tab is not on the same side as terminal 30. Who makes those relays and part#? I bet they are not direct replacements for Bosch or P&B SPDT relays. I ran into one off brand relay that which one of the terminals was not 87 but 87B. Get some Bosch relays and i bet your problem will be fixed.
Karl
Nonono333
Member - Posts: 22
Posted: September 15, 2002 at 3:32 AM / IP Logged
WHERE DO YOU LIVE, I LIVE IN SAN DIEGO AND JUDGING FROM YOUR USERNAME, I HAVE A FEELING YOU DO TOO. WELL THROW AWAY THE FIVE WIRE RELAY CONFIG CRAP. THAT IS DINOSAUR EQUIPMENT. I HAVE A 5-WIRE MODULE THAT IS PREWIRED  AND CAN BE USED FOR MANY DIFFERENT APPLICATIONS. FOR MERELY 5 BUCKS, YOU CAN BE A PROUD OWNER OF ONE.LOL. IT WILL MAKE YOUR INSTALLS A WHOLE LOT CLEANER ALSO.
steve p.
audiopro12
Member - Posts: 10
Posted: September 15, 2002 at 1:56 PM / IP Logged
if you intend to use these relays thats your choice it will work I think you need to check the bottom of the relays and attach accordingly
terminal 30 of the realys should go to the actuator one relay to each actuator wire, then you should hook both 87a's to ground then hook 87's and 86's to 12volts ....then use a negative to trigger the unlock relay at term.85  and neg to trigger term 85 at the lock relay ...if that doesnt work then try new relays ....
hope this helps
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
