Tacoma Crimestopper Alarm Install help
tyger23
Member - Posts: 9
Posted: July 25, 2004 at 7:29 PM / IP Logged
I have my Crimestopper CS-2016FM alarm installed and everything seems to be working except the door locks.
I have my green lock signal from the crime stopper connected to the BLACK/ Blue wire at the 12 pin connector in the drivers kick panel. I have the blue unlock wire connected to the RED / Yellow in the same location. Both wires are diode isolated from the module with the cathode facing the alarm. This was per the install instructions.
When I arm the alarm nothing happens. I have probed the signal coming out of the module and I do not see the negative pulse that is supposed to happen. Similarly, there is no pulse from the unlock wire from the module.
Am I missisng something? Do I have my connections correct? Do I have a bad brain?
Thanks for all the help.
tyger23
Member - Posts: 9
Posted: July 25, 2004 at 9:20 PM / IP Logged
Forgot to mention that it's a 2001 Taco 4-door.
draasch
Gold - Posts: 2,172
Posted: July 25, 2004 at 9:44 PM / IP Logged
Power Lock BLACK/ BLUE 12 PIN CONNECTOR IN #209
Power Unlock RED / YELLOW DRIVER KICK PANEL ***
*** Child Safety Locks:GREEN/ BLACK In 12 Same Connector As Door Lock Unlock Wires. #209 - See Child Safety Door Lock Diagram.
http://wiringinstructions.com/209.htm
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
tyger23
Member - Posts: 9
Posted: July 25, 2004 at 9:54 PM / IP Logged
Thanks for the suggestion, but doesn't that just affect the unlock? I can't get the lock to work either.
draasch
Gold - Posts: 2,172
Posted: July 25, 2004 at 10:18 PM / IP Logged
read the detailed info on the note that i sent you.......and see if that is what is happening.....
Good Luck
David
Ace Security
813-376-9778
Tampa
tyger23
Member - Posts: 9
Posted: July 26, 2004 at 9:51 PM / IP Logged
Success!
However, it took a lot more work than I hoped. It seems that the Crimestopper was not providing a good ground connection to activate the negative door locks. It was around 100 ohms or so and the relay would not activate.
I got around this by using the Crimestopper's positive door lock/unlock circuit to activate an external power relay that in turn properly grounded the lock/unlock signals. Voila! All is working.
And David, I did have to use the child safety switch. I diode isolated it to operate with the unlock relay. Seems to all be working now.
Thanks all for the help!
