11-volt relay?
joeyoone
Member - Posts: 8
Posted: July 27, 2004 at 12:40 AM / IP Logged
The accessories output wire on my alarm only outputs 11.2 volts; it doesn’t seem to work with your standard BOSCH 12volt relay. Where can I find an 11-volt automotive relay? I’m only using the relay to convert polarity, so a high current relay is not necessary. Thanks
xetmes
Silver - Posts: 586
Posted: July 27, 2004 at 7:50 AM / IP Logged
It should work, infact if it doesnt there must be something wrong. auto relays will pull at around 8V and should definitly work at 11V
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
