Viper 791XV on a manual transmission?
kellyk
Posted: August 04, 2004 at 7:00 AM / IP Logged
Is it possible to put this system on a manual transmission?  If not, does anyone know of a system that offers the same featurs as the Viper but for a 5spd.
raydawg357
Silver - Posts: 769
Posted: August 04, 2004 at 3:37 PM / IP Logged
It's possible but not recommended.
Do it right the first time
kgerry
Platinum - Posts: 3,455
Posted: August 04, 2004 at 3:44 PM / IP Logged
Autostart and Compustar make similar units for manual transmission vehicles
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
slade781
Member - Posts: 43
Posted: August 04, 2004 at 5:42 PM / IP Logged
Yeah, it's possible but I heard that there are a lot of problems that could occur.  But then I talked to some other people who has it installed and they haven't had any problems so I don't really know.....  Viper 791XV on a manual transmission? -- posted image.
kellyk
Posted: August 05, 2004 at 10:49 AM / IP Logged
Maybe I won't go that route then......   I have herd good things about CompuStar.... 2WSS-AS  that would be my second choice...
Thanks .....
profuse007
Gold - Posts: 2,015
Posted: August 05, 2004 at 12:08 PM / IP Logged
Thanks .....
my first choice would be compustar if it goes on my car, IMO. i like the wire layout better than DEI for easier installation.
Houston,TX
Rhpf
Member - Posts: 11
Posted: August 05, 2004 at 4:40 PM / IP Logged
I have a 790 (same unit essentially, just diff remote) anyways I had no problems on my 6spd manual. The unit comes with an on/off switch, ground it and then leave it off if you know someone other then yourself is going to be using the car (so they dont accidently start it and run it into something). In the entire time I had the car I accidently started it once in gear but was able to stop it before it cranked all the way. (you have a decent amount of time to react).
04 Silverado EC
kellyk
Posted: August 06, 2004 at 3:26 AM / IP Logged
After reviewing the CompuSTAR.. its seems they are know for their extreme range.  I am really attracted to that. The Viper has a good reputation, but everyone talks about range of the 2WSS-AS, the spread spectrum.
With the Compustar 2WSS-AS what brand proximity senser or microwave sensor as well as glass breakage sensor would you guys recommend?
kellyk
Posted: August 06, 2004 at 3:30 AM / IP Logged
After researching the CompuSTAR brand I find that they are really known for their range.  Im really attracted to that. DEi has a really good reputation, but that vs. the spread spectrum reviews make it a hard one.
With the CompuSTAR 2WSS-AS, what brand proximity or microwave sensor and glass breakage sensor would you guys recommend?
