97 dodge dakota door locks
Pjnc284
Posted: August 06, 2004 at 8:35 PM / IP Logged
I have a 97 dodge dakota that originally came with factory keyless entry. The wiring info that came with the alarm said that those without keyless entry were postive trigger and those with were 5 wire reverse polarity, but other wiring info pages don't say anything about it. Just wanted to see if someone could confirm this. I snooped around the internet and found a diagram for the 5 wire rev. pol. The link below is a paint drawing I did from the central door lock outputs in the alarm(left) and the corresponding hookup as listed on another website. Door Lock
draasch
Gold - Posts: 2,172
Posted: August 06, 2004 at 11:11 PM / IP Logged
Power Lock L GREEN/ BLACK ** 12 PIN BLACK CONNECTOR BELOW #203
Power Unlock PINK/VIOLET FUSE BOX BEHIND DRIVER DASH
#203 - See Reversal Rest At Ground Door Lock Diagram. ** Also Can Be Found As ORANGE / VIOLET.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
