Matrix 3.5 with 508D
sesmith
Posted: August 07, 2004 at 11:37 AM / IP Logged
I have the GREEN/ blue wires on the 508D connected to the loose blue wire on the shock sensor harness. Will warn away and instant trigger both function with it connected like this? If not, how do I connect it to get both stages working?
profuse007
Gold - Posts: 2,015
Posted: August 07, 2004 at 11:50 AM / IP Logged
if you wire it into one, you dont have 2 stage anymore.
for 2 stage wiring:
-blue(full trigger)- hook it to a "instant trigger" that youre not using, possibly the trunk trigger or whatever zone fits ur need to distinguish a trigger.
-GREEN/ blue (warn trigger)- hook it to the impact sensor, possible be green depend on the maker. remember to properly diode isolate the two wires so it doesnt criss-cross w/ each other.
Houston,TX
kgerry
Platinum - Posts: 3,455
yes.... anything less than .8 seconds will trigger warn away, any pulse longer than .8 seconds will trigger full alarm  and i think it will show up as a zone 4 trigger
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
extreme1
Silver - Posts: 1,070
Posted: August 07, 2004 at 11:54 AM / IP Logged
There should be a loose green wire on the shock harness. but yes, both green and blue go to the one wire. This will give you dual zone perimeter still
Shaughn Murley
Visions Electronics
Red Deer, Alberta
lilboi
Copper - Posts: 126
Posted: August 08, 2004 at 2:26 AM / IP Logged
I dont' get it. There's a loose blue wire. And another blue wire that loops around. What does the loose one plug into.
foxhound
Member - Posts: 37
Posted: August 08, 2004 at 11:50 AM / IP Logged
On mine there is a loose green one and a blue that loops. I was planning on using a diode to connect it to the blue wire of the 791xv and connecting by backup battery with a diode to the same blue wire. Will that work with two stages still?
foxhound
Member - Posts: 37
Posted: August 08, 2004 at 11:51 AM / IP Logged
On mine there is a loose green one and a blue that loops. I was planning on using a diode to connect it (the loose green) to the blue wire of the 791xv and connecting my backup battery with a diode to the same blue wire. Will that work with two stages still?
sesmith
Posted: August 08, 2004 at 12:38 PM / IP Logged
On mine the blue wire that loops is connected to the shock sensor orange wire. The loose blue wire is on the other end of the shock sensor harness that plugs into the brain.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
