remote starter
rookie install
Member - Posts: 6
Posted: September 17, 2002 at 1:20 PM / IP Logged
Im having a problem with a remote starter for a 1997 nissan altima, me and afriend are using a viper 550.  the problem is we cant get the car to turn over w/ the remote starter. the system came with the three relay hook-up & the car comes with two starter wires ,we tried to run the output from the one starter relay to both wires and still nothing happened......       any help u can give would be greatly appreciated      -->Rookie<--remote starter -- posted image.
Platinum - Posts: 12,488
Posted: September 17, 2002 at 3:20 PM / IP Logged
You do not need to hook up a relay in order to power both starter wires. Just jump the two together with a wire and it will do the same. You when doing remote start, the accessory wire must be isolated from the keyswitch with the accessory relay. ( red to BLACK/ pink ).
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
