2004 4Runner factory immobiliser disable
excelon
Posted: August 30, 2004 at 4:52 PM / IP Logged
I'm installing a remote starter but I need to know how to disable the OEM immobiliser on a Toyota 4runner 2004 or at least know where the brain is located in order to permanently disconnect it.
If anybody knows about this please help me out!
NOTE: Where I live, there are no Bypass Kits available in the market so I need to do this like the old times
profuse007
Gold - Posts: 2,015
Posted: August 30, 2004 at 5:52 PM / IP Logged
-if you do that, you have to rewire ur ignition system. i know you dont want to do that.
-if someone point out the location of the unit, plz do not attempt to bypass it permanently. youll leave urself stranded w/o a car like one member here tried to bypass his immobilzer on his f150 supercrew.
-EBAY.com ur friend, take advantage of it.
Houston,TX
auex
Platinum - Posts: 5,041
Posted: August 30, 2004 at 6:12 PM / IP Logged
Do not get cheap on this issue, or THIS WILL HAPPEN. You will not find any easy way to bypass the immobilizer. Buy a "Key in the box" type defeat, such as 555U. As far as no kits being available where you live, then buy one over the internet.
NOTE: As far as the location of the "brain", it is built into the ECU, engine control unit.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
JWorm
Platinum - Posts: 2,208
Posted: August 30, 2004 at 6:51 PM / IP Logged
No bypasses available in Panama? Make one out of 22 gauge wire, a relay and a spare key.
You don't want to attempt to permanately disable the imobilizer.
Steve #1
Member - Posts: 35
Posted: August 30, 2004 at 10:56 PM / IP Logged
Based on the above suggestions, I'll assume that the Toyota uses an RFID transponder system.
Here's a how-to for the old school DIY bypass JWorm mentioned.
