2004 dodge neon srt-4 remote start
customcarelectr
Member - Posts: 43
Posted: August 31, 2004 at 2:08 PM / IP Logged
can somone provide me with the wiring info for this car
thanks
mo12v
Posted: August 31, 2004 at 3:11 PM / IP Logged
Constant 12 voltsPINK/BLACK & REDIGNITION SWITCH HARNESS
Ignition 12 voltsDARK BLUE (14 gauge)IGNITION SWITCH HARNESS
StarterYELLOW (14 gauge)IGNITION SWITCH HARNESS
Dome LightYELLOW (-)DRIVER'S KICK PANEL
Trunk Pin SwitchTAN/BLACK (-)AT LIGHT IN TRUNK
Parking LampBLACK / YELLOW (+)STEERING COLUMN OR RKE*
Power LockLT.GREENDRIVER KICK PANEL **
Power UnlockSINGLE WIRE SYSTEMSAME AS LOCK **
* RKE Module Located At Access Panel On Top Of Dash **LT GREEN Door Lock Wire Must Recieve A (-) Negative Ground Pulse Throu A 1K Ohm Resister To Lock And A (-) Negative Ground Pulse Through A 250 Ohm Resister To Unlock.
Accessories
Window UpD\ LIGHT BLUE P\ BROWN / WHITE @ MAIN SWITCH
Window DownF/ WHITE/ LT BLU F/ VIOLET/WHITE REVERSAL AT GROUND
Ign Key WarnL BLUE (-)STEERING COLUMN HARNESS
Trunk ReleaseBROWN / LT BLUE (-)TRUNK RELEASE SWITCH OR RKE *
OEM HornBLACK/ RED (-)STEERING COLUMN HARNESS OR RKE *
HeadlightsVIOLET/WHITESTEERING COLUMN HARNESS
OEM Alarm ArmLT GREEN/ ORANGEDRIVER KICK PANEL **
OEM Alarm DisarmSINGLE WIRE SYSTEMSAME AS ARM **
Reversal Rest At Ground Window Circuit . * RKE Located At Access Panel At Top Of Dash ** LT GREEN/ ORANGE Wire Must Receive A Ground Pulse Through What Has Been Reported As A 2.7K Ohm Resistor To ARM/LOCK And A Ground Pulse Through What Has Been Reported As A 7.5K Ohm Resistor TO DISARM, Double Pulse Will UNLOCK
Remote Start
Tach SignalBLACK/ GREYAT COIL
Ignition #2BLACK/ ORANGEIGNITION SWITCH HARNESS
Ignition #3
AccessoryBLACK/ ORANGEIGNITION SWITCH HARNESS
Neutral SafetyYELLOWIGNITION SWITCH HARNESS
Brake LightWHITE/ TAN (+)SWITCH AT TOP OF BRAKE PEDAL
Reverse LightVIOLET/BLACK (+)6 PIN CONN POS 1 BEHIND DRIVER'S KICK
Rear Window DefrostBLACK/ WHITE (+)5 PIN CONN BACK OF REAR DEFOG SWITCH*
Immobilizer Bypass Circuit . * Must Use Relay- High Current Output To Defrost Grid RKE ACC +12v- DK BLUE/WHITE At RKE. RKE Located At Access Panel, Top Of Dash. Programming An Additional Transponder Key Requires 2 Valid Sentry Keys.Key 1 On 5-7 secs.Off,Replace W/Key 2-On,After Tone,Replace W/New Key-On Till Tone.
MO
