96 accord oil light for remote start?
alexcvn
Member - Posts: 9
Posted: September 04, 2004 at 8:27 AM / IP Logged
Hi, I'm trying to get my car to start remotely. It only crank but not long enough to start the car. Then took a look at the manual, it tells me that I have to either connect the wire to an oil-light indicator or wrap 5 times around high tension coil. Well I tried to wrap it around the ing. coil inside the ign. cap, but doesn't work. I don't know where to find the oil-light indicator wire. Could somebody tell what color it is? Thank You.
mo12v
Posted: September 04, 2004 at 9:51 AM / IP Logged
"wrap 5 times around high tension coil".............  I beleive that means Spark Plug Wire.
What type Remote Start Unit is this?
MO
alexcvn
Member - Posts: 9
Posted: September 04, 2004 at 10:58 AM / IP Logged
Alphaguards
Platinum - Posts: 12,488
Posted: September 04, 2004 at 11:49 AM / IP Logged
read this post: https://www.the12volt.com/installbay/forum_posts.asp?tid=33628&KW=oil+light
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
